Engine Surging
Old Dec 15, 2003 | 06:52 AM
mayhem's Avatar
Engine Surging
I had to take the Evo out in the snow and salt yesterday. After I was done I decided to take it to a touchless automatic car wash. Just good enough to get most the salt off the car.
While in the wash my engine began random surges up to 1500rpm. It was already at full warm up and idling around 700-800 like normal. Everyone in the car noticed that it only seemed to surge when the spraying was at the front passenger side of the car. It was a slow surge and decline back to normal. Like it was computer controlled. Sprayer got the front right and it would climb to 1500 very smoothly and hold for about a half second then very smoothly decline back down to 700-800.
I can't think of any GOOD reason as to why this would happen. Maybe water mist was entering the intake...???
Extra info: I have the Works reflash and axle-back exhaust. Nothing else. I had the heater on (set on blowing out the dash on to the windows) and the fan set on "1". My headlights were on and so was the CD player.
Old Dec 16, 2003 | 05:56 AM
mayhem's Avatar
Bump. Any ideas?
Old Dec 16, 2003 | 07:36 AM
Secret Chimp's Avatar
Re: Engine Surging
Originally posted by mayhem
....Maybe water mist was entering the intake...???
I think you answered your own question right there.
Those touchless car washes blow water at very high psi....as a result it creates a very fine mist that just hangs in the air. That moisture could get into your engine and effect the firing of the cylinders.
Don't sweat it though...taking in water vapor r mist won't hurt anything in the long run.
SC~
Old Dec 16, 2003 | 10:09 AM
LateSleeper's Avatar
Just curious, mine will do the same when I have the front defroster on. My idle will spike to 1200-1500 at a light if I have the front defroster on. I suspect that it is the compressor. It should be fine.
Old Jan 5, 2004 | 08:58 AM
Ultor's Avatar
Mine was doing the same thing this morning.
It happen as soon as my GF turned on the defroster.
Every stop light it would go from 850rpm to about 1200, then lower itself.
Old Jan 7, 2004 | 08:20 AM
Ultor's Avatar
Is this happening to anyone else.
Does anyone have an explanation?
Old Jan 7, 2004 | 08:37 AM
Hungbee112's Avatar
Happens to me too. It never happened when it was warm outside, dont know if that helps.
Old Jan 7, 2004 | 08:40 AM
YellowFever's Avatar
It's normal.
Old Jan 7, 2004 | 08:43 AM
mikesevo8's Avatar
On some cars, using the defroster also engages the A/C.
You want to blow dry air on the window to get rid of any fog on the inside.
Perhaps this is what is happening with the Evo.
To test, turn on the defroster and go look under the hood to see if the A/C clutch engages.
Old Jan 7, 2004 | 01:29 PM
Zeus's Avatar
The Evo's A/C is engaged with the defroster...
Old Jan 7, 2004 | 01:33 PM
93civEJ1's Avatar
i know what it is....its your fan on your car turning off and on...listen closely and you will here it kick on and off when you notice this surge.
Old Jan 7, 2004 | 02:30 PM
webguy330i's Avatar
It's the a/c kicking on. It comes on whenever you are past the footwell/front defrost mark on the fan direction dial, or if you click the a/c button on manually of course. I really wish it would just light up the a/c button for you, allowing you to turn it off because most of the time I don't need my air "conditioned" for defrosting purposes (i.e. removing 3" of ice from the windshield).
Old Jan 7, 2004 | 02:34 PM
SAEVO's Avatar
It is true, its the A/C kicking on, look in the owners guide book
Old Jan 7, 2004 | 03:51 PM
Zeus's Avatar
I hate that too... even more so is the recirculation turning off... Damn it, I want the recir. on almost all the time. The driver is supposed to control the vehicle damn it! I'm about to tear the dash apart and start cutting and splicing (end of rant )...
4RETECH
Sep 23, 2016 05:05 AM
Jose_c93
Lancer Engine Tech
10
Jul 18, 2014 02:24 PM
dbsears
Northwest Region
16
Sep 25, 2011 07:20 AM
nudge120
Jan 18, 2010 09:03 AM
krazy srt4
41
Apr 27, 2008 06:49 PM
