5th synchro upgrade?
Old Mar 15, 2011 | 08:10 AM
JDavenport's Avatar
Originally Posted by cfdfireman1
If you have to rush a shift into 5th you already lost the race. Use your fingertips and feel it go in.
Good point, I'm not racing yet, just NASA DE3. I don't really go hard at gear changing, but I might need to revisit what I'm doing.
Old Mar 15, 2011 | 08:55 AM
AlwaysinBoost's Avatar
I don't have an answer to your question specifically, but chewing up 5th gear has been a real worry of mine since I started tracking the car. Luckly I haven't had any issues, but as I get faster and faster I'm using 5th more and more and its only a matter of time till my concerns come to furition.
I have an upgraded trans w/REM coatings and the works. I also change my fluid on a pretty regular basis (maybe every 3-4 track days). I'm thinking the next step is a trans cooler w/pump to keep temps in check. I also just implemented gear based boost control so I can attempt to keep the load (boost) in 5th gear to a minimum. Just a couple items for thought.
Old Mar 15, 2011 | 12:15 PM
JDavenport's Avatar
Oh, I don't think 5th gear itself is an issue. Mine still runs smooth and clean in 5th. Just going from 4-5 is rough because the synchro laid down.
Old Mar 15, 2011 | 05:37 PM
TIGERJC's Avatar
Originally Posted by JDavenport
So is the double synchro an upgrade over the stock setup? I'm only in the 360-370 range, but road racing presents a whole different kind of wear and tear.
yes. You might want to try changing your trans fluid more often (after 2-3 track days) and ask around to see what trans oil cocktail may help
Old Mar 15, 2011 | 07:11 PM
JDavenport's Avatar
I change all the driveline fluids every 2 events. Redline MT-90 for the tranny.
Old Mar 15, 2011 | 08:37 PM
Aby@MIL.SPEC's Avatar
i thought it was tre that had the 5th gear double synchro upgrade....
it's rushing the gear change with the big drop between 4th / 5th gear.
what is the max speed of a 6spd 5th gear @ 7k revs?
is your car a dd or 60% track car?
KillaYayo
Aug 31, 2016 07:31 PM
Jacks Transmissions
Jacks Transmissions
13
Apr 4, 2013 12:03 PM
bluebyu34
15
Feb 28, 2013 03:01 PM
MitsuJDM
Oct 10, 2011 09:21 AM
Porsche518
29
Dec 20, 2003 12:06 AM
