Post-Intake Installation Observations
Old Dec 16, 2003 | 11:09 AM
nebolic's Avatar
if you install an open air intake, wouldn't you be running it more lean instead of rich? i thought more air = leaner mixture?
any thoughts?
Old Dec 16, 2003 | 12:56 PM
Deceit's Avatar
Yes, your mixture will lean out a tad, this is how intakes create power with our MAF system.
Old Dec 16, 2003 | 01:13 PM
camdog17's Avatar
it would actually lean out? I thought it would actually make your car run rich, 'cause the engine is getting more air, thus it thinks it needs to add more fuel. Am I wrong?
Old Dec 16, 2003 | 07:29 PM
rraulston's Avatar
it was backwards!!!cant freaking believe it!!! picture 25 on the k & N instructions show it on backwards. Those shmucks!!!!
Old Dec 16, 2003 | 07:33 PM
MalibuJack's Avatar
Originally posted by rraulston
dang. how do you know if the bov is backwards????
Easiest way to make sure its not backwards is to make note of the orientation of it when you took it out, Digital photo works best..
And you'll frequently see documentation shows the stock DV backwards, I don't know why, but almost everyone has done it at least once.
Old Dec 25, 2003 | 11:26 PM
boostedwrx's Avatar
yea, the only way your intake is making power is by leaning out the af mixture. Id like to see what the maf readings look like from running this filter.. You are probably running lean in the 3500-4000 range.
Old Dec 26, 2003 | 04:33 PM
HoustonEVO's Avatar
If you live in AZ or in any place with dusty conditions you should buy the K&N drycharger. This is a cover that goes over the filter for a prefilter. At most it might rob 1-2 hp. And if your racign at a track just take it off for the day (it just pulls over the filter no tools needed).
daniel_f_us
Aug 23, 2011 06:20 AM
Rob W.
Jan 11, 2008 01:22 PM
Invoice EVO
Apr 10, 2006 03:27 PM
Daemon GPF
12
Apr 1, 2006 10:08 AM
