Tial 44mm WG help!!please
Old Mar 24, 2011 | 07:49 PM
Evoleader88's Avatar
i just got done installed my 6262 set up, and when it come to start up the WG (tial 44mm) staying open and exhuast air dumpin out of it... and check the vacum lines where it hooked up to the MBC: turbo goes bottom MBC, side WG nipple goes to the side of the MBC. then i tried to switch to the top nipple of the WG and still staying open...any idea? may be WG is bad? solution = valve seal
UPDATED: so i put my valve seale back on and finally got it start back up and the dumptube stop dumping air, then i tried to drive it but everytime i let off the gas pedal the ignition shut off (reverse and 1 st gear), the rpm jus dropped all of way down and shut my car off ( jus installed AEM and SD), even in neutral and i rev it does the same thing, i checked every vacumm line, piping and plugged all the unused vacum nipple and everything seem tight and no leak. idk what goin on, oh yea and the car idle pretty rough and loud too, i know i have cams but it idle like when u blew a pipe or a coupler (but all the pipe are connected properly)...anyone have any idea whats going on?
Old Mar 24, 2011 | 07:58 PM
n2oiroc's Avatar
sounds like you forgot the valve seat.
Old Mar 24, 2011 | 07:59 PM
what is the valve seat?
Old Mar 24, 2011 | 08:01 PM
n2oiroc's Avatar
here is a pic. it goes in the bottom of the wastegate between the valve and the flange on the manifold.
http://www.himni-racing.com/images/t...lve%20seat.jpg
Old Mar 24, 2011 | 08:03 PM
holly **** i took that off!!!.... shyt i gott find it
Old Mar 24, 2011 | 08:08 PM
n2oiroc's Avatar
here is what it looks like installed.
half way in.
without it.
Old Mar 24, 2011 | 08:15 PM
canitbethislong's Avatar
haha, yes sir thats why the fire ring is taped into your wastegate when you get it new lol. If not they sell them again.
Old Mar 24, 2011 | 08:22 PM
omg!!! i found the valve seal!!!!!! i though i threw it away.... thanks for telling me guys!!! ill put it back on and will update the result
Old Mar 26, 2011 | 08:50 PM
Last problem fixed, here come to another one... please read the op
galantman03
43
Feb 5, 2017 09:54 PM
drb
53
Oct 25, 2016 07:50 AM
black E
11
Oct 21, 2014 04:34 PM
BOOST_ADDICT
Feb 4, 2014 01:03 PM
svt_lightning01
Mar 31, 2011 01:08 PM
