hybrid turbo flow?
hybrid turbo flow?
ok i am completing my motor build and also now going with a lager turbo it is a garrett
turbo chra first off the turbine is an 80mm/ 56mm exducer, and the compressor will now
be a 56mm/74 exducer if memory serves correct
help me with input of what power it should make and what it whould flow
thanks in advance
thanks in advance
thanks in advance
thanks in advance
Not Sure what exhaust wheel that is but a 50Trim which can make 500HP:
Turbine is Stage III --- 65mm/56mm exducer
Compressor is about --- 55mm/76mm exducer
