late spool up
Old Mar 28, 2011 | 11:19 AM
dinok's Avatar
late spool up
i was driving my evo 9 fpred i have cams and supertech kit and headstuds in the head
i was opening it up in 1st gear and at 7800 i heard a slight pop noise and the spool up was effected instead of the full boost (25psi) hitting at 3900 rpms like usual its hitting about 4700
any pointers on wat cud be the issue
i dont hear any knock from the engine no noise that seems an issue coming from the engine
the turbo sounds the same doesnt seem like its blown or the turbine is off balance
maybe a boost leak ??
or the wastegate ??
any help wud be awesome !
thanks
Old Mar 28, 2011 | 11:20 AM
Sharkbite2000's Avatar
VAC hose one popped off ?
Old Mar 28, 2011 | 12:18 PM
dirtylilevo's Avatar
Im dealing with the same issue except on a Tomei arms M7960 but I got the car like it is. Im trying to figure it out. This might help/can help each other... https://www.evolutionm.net/forums/sh...ght=slow+spool
Old Mar 28, 2011 | 12:28 PM
turbotalawd's Avatar
Do a boost leak test. Sounds like something popped off.
Old Mar 28, 2011 | 01:14 PM
dinok's Avatar
cool will do when i get home !!!
any other ideas from neone ?
Old Mar 28, 2011 | 09:04 PM
dinok's Avatar
PUlled a p0243 code which is wastegate malfunction
Is it possle this causes the late spool ???
The wastegate cuda been the pop noise i heard b4 spoolup delay was noticed
Old Mar 28, 2011 | 09:07 PM
Reved up's Avatar
Maybe issue with bov? Try taking it apart or swap springs on it. Doubtful its the problem but who knows.
Id personally check all your houses.
Old Mar 29, 2011 | 06:34 AM
dinok's Avatar
bump !
Old Mar 29, 2011 | 12:11 PM
dinok's Avatar
Noone has had any issues wit this code !?
Old Mar 29, 2011 | 01:32 PM
I've got all my trouble shooting pointed to wastegate. If you have a code saying wastegate malfunction than that only supports the possability. Im pulling turbo to look at my wastegate!
Old Mar 29, 2011 | 09:03 PM
sparky's Avatar
Originally Posted by dirtylilevo
.... Im pulling turbo to look at my wastegate!
No need to yank off the complete turbo to check out the WG. 1) The wastegate actuator can be removed simply by removing two bracket bolts on the compressor housing and removing the cotter pin that secures the end of the actuator rod onto the flapper arm. 2) To inspect the wastegate puck(flapper valve) just remove the turbine housing.
There is no need to R&R the complete turbo. No need to hassle with disconnecting the oil and water feed/return lines. They are a hassle to reinstall man.
Old Mar 30, 2011 | 07:47 AM
dinok's Avatar
i think what happened was i hti a fuel cut and nwo i have a boost leak .. bc im still hittin full boost but a 1,000 rpm later
and that pop noise is prob a vacume line that is disconnected
Old Mar 30, 2011 | 11:16 AM
dinok's Avatar
bumppp
Old Mar 31, 2011 | 11:16 AM
I pulled everything apart after trouble shooting everything else and found that it was the wastegate... It was only covering half of the outlet. [IMG][/IMG]
Old Mar 31, 2011 | 12:11 PM
dinok's Avatar
and did u have the same issue with still hitting full boost but having late spool up ?
