Over heating problem help!
Old Apr 3, 2011 | 10:24 PM
5LEEPERISAH23I's Avatar
so i was driving today for about 20 mins turned it off everything was normal. Then it on again tonight n the car started to over heat. turned it off let it sit. i was 1 mile from home down hill so coasted home..
i let the car cool down...checked the COOLANT was full like normal
but it was over heating what could be the problem?
what it is NOT:
no air bubbles in the system
Coolant is not low
Not burning out the tail pipe
Waterpump is still on belt
Themastat is replaced and still not working!?!!?
Old Apr 3, 2011 | 10:28 PM
tscompusa2's Avatar
air bubbles in the coolant system. start it up with the cap off the radiator and watch your coolant level in the overflow tank.
Old Apr 3, 2011 | 11:05 PM
RSMike's Avatar
could be many things.
blocked radiator
broken (shut) thermostat
broken waterpump
belt come off waterpump
check to see if the heater is hot when the car is hot.
this will confirm the water pump working.
if the belt on the waterpump is still there and the fan is hot, check the top radiator pipe.
If that is cold, then you probably have a broken thermostat or a blocked pipe.
how were you driving when it overheated?
Check to make sure your cooling fans are working too
Old Apr 4, 2011 | 08:23 AM
blocked radiator
broken waterpump
i just took it out for a spin. there is coolant to the top in the system there are not bubbles i did what tscompusa said to do first. I idle it holds normal coolant temp... when i start to drive normal it goes up, if i put it in Neutral when driving it goes back down.
the radiator hose is hot. so i think the thermostat is good.
so maybe the water pump just took a sh*t maybe? i just replaced it about 10k ago tho
I also felt the rubber hose going from the block to the radiator, it was warm but not hot to the point i couldnt hold it
Old Apr 8, 2011 | 01:46 PM
thremastit isnt the problem. Is there anything else it could be before i spend $200 on a Waterpump
Old Apr 8, 2011 | 03:12 PM
motormilitia's Avatar
You could try a coolant system flush.
RSMike's Avatar
blocked radiator.
is the radiator hot when its overheating?
are the fans turning on?
have you changed your water/coolant?
Old Apr 8, 2011 | 03:29 PM
tscompusa2's Avatar
sounds like a huge air bubble to me.. and as i told you on aim its not the waterpump. have you ever even looked at a waterpump before? its just a blade that spins attached to a pulley that is belt driven..
when a waterpump goes bad theres a weep hole that leaks coolant, which in return notifies the owner of the vehicle the gasket is so worn down that its time to change it.. if theres no coolant coming from the waterpump its not that.. plus it would squeel.
Raceghost
Aug 10, 2018 10:39 PM
Chrushev
Lancer Troubleshooting
12
Jul 25, 2017 02:16 PM
Jbundrick
Jul 18, 2017 02:17 AM
Turbojoe89
Oct 14, 2016 06:45 AM
CrackerJackToy
Oct 29, 2007 04:45 AM
