Evo 8 10 PSI???
Old Apr 20, 2011 | 11:10 AM
WhItEVIII's Avatar
So what if im hitting only 7lbs, im having this problem also but only hitting 7 to 6 pounds and it feels like I hit fuel cut. Current mods are cat back, 10.5 hot side, stock intake with cone filter and I pulled the fuel pump out and found out it has a 255 walbro. And what pill are y'all talking about
Old Apr 20, 2011 | 11:23 AM
REV.olution's Avatar
pm'ed you with answer.
Old Apr 20, 2011 | 11:33 AM
goodhart's Avatar
^^^Why PM? post it up so others may benefit from the answer too. Isn't that the whole point of a forum?
I am helping a buddy with the same issue.
Only building ~5-6psi (good boost gauge) and feels doggy as all hell.
- There is no BCS, just an empty plug.
- MBC is hooked up correctly
- Is not a boost leak
- Turbo has no shaft play
would the BCS being not hooked up cause this?
The only code it is throwing is a P0243 Wastegate solenoid. I'm sure the code is from the BCS not being there, but would that alone cause it to only make 5-6psi at WOT????
Old Apr 20, 2011 | 05:19 PM
WhItEVIII's Avatar
^ So I called one of my buddys and he told me the lines are hooked up correctly and that it might be a bosst leak. Did you figure out what was wrong with your buddys car? Also another friend told me it might be in some sort of safe mode since Im not tuned anyone ever experience this. I only hit 7psi at WOT
Old Apr 20, 2011 | 05:35 PM
goodhart's Avatar
Didn't hear from him today. I'm not sure. I have never heard of a "safe mode" for 8/9's though
Old Dec 12, 2011 | 12:48 PM
xXlEVOlXx's Avatar
Originally Posted by ColoCortez
Go down to your local Mitsu dealership and purchase part # MN 143555. This is the factory boost/vacuum hose assembly and includes the two(not one) restrictor orifices, the proper "T", and all the needed hose clamps. Install the new factory hose assembly and then get back to us.
^^^^^ Sparky thanks man got the assembly and just like that problem solved... Thank you all so much.
how much was the boost/vacuum hose assembly? im boosting 10-11psi as well and came down to the same conclusion of it being the restrictor pill
Old Dec 12, 2011 | 05:31 PM
WhItEVIII's Avatar
I didnt see or find any pill in the hose assembly my problem was simply not beign tuned. I installed a Hallman pro MBC and tuned the car, after that the car started running fine.
Old Apr 11, 2012 | 06:01 PM
Colbyy's Avatar
Just took my car out for the spring, boosted to 20 fine then way home only get to 10 then it flutters down. Just checked and can feel the pills in the lines.. Ideas?
Old Apr 11, 2012 | 07:08 PM
WhItEVIII's Avatar
What pills those everyone talk about, you sir could have a boost leak
Old Apr 12, 2012 | 04:35 AM
Colbyy's Avatar
That was my guess but I came across this last night. Replaced all the new couplers back to the old ones (pipes were blowing off) once I get the valve cover back on just see and look for leaks I guess
Old Apr 12, 2012 | 07:09 AM
sparky's Avatar
Self-deleted
Old Apr 12, 2012 | 10:31 AM
WhItEVIII's Avatar
If the new ones are blowing off spray a bit of hairspray on them and use t clamps that should do the trick
Old Apr 12, 2012 | 03:39 PM
Colbyy's Avatar
Yeah thanks some one else told me that, that was next after I get it back together and figure out the boost problem
Old Apr 12, 2012 | 04:37 PM
WhItEVIII's Avatar
No prob
Old Apr 29, 2012 | 04:09 PM
Colbyy's Avatar
Got car all back together today. Only boost to like 8lbs and stops and flutters down.. Ideas? Think I'll start by ordering those hoses
