Evo 8 10 PSI???
Old Apr 1, 2013 | 03:21 PM
  #31
414Evo8's Avatar
Same problem
Originally Posted by ColoCortez
Go down to your local Mitsu dealership and purchase part # MN 143555. This is the factory boost/vacuum hose assembly and includes the two(not one) restrictor orifices, the proper "T", and all the needed hose clamps. Install the new factory hose assembly and then get back to us.
^^^^^ Sparky thanks man got the assembly and just like that problem solved... Thank you all so much.
I had the same problem too and did what sparky said. When down to the dealer to order part # MN 143555. A few days later I installed it and just like that Its boosting 19lbs again. I almost ended up spending $700 on other parts that people said could be the problem. FYI-the part cost $30. This is way cheaper then any other parts. If anyone is boosting only 10psi, go buy that part first because its gonna save you a lot of money.
4dooradam
Jun 21, 2016 06:29 AM
moogatwo
Jul 7, 2015 09:33 AM
vr4gasmtt
Jun 14, 2015 10:12 PM
SLO-EVO
45
Mar 27, 2014 11:09 AM
smp3000
Jul 8, 2009 04:50 PM
