fp turbos
Old Apr 10, 2011 | 01:50 AM
stck_trbo_mnstr's Avatar
fp turbos
Every time I go to see races I see all these big turbo evos getting pulled on by smaller trbo less horsepower evos with turbos like the hta fp green or the fp red.
is this because of the power these cars are making and how efficient are the turbos at those power levels?
in order to be efficient what power does an fp black, fp red, and fp green have to make?
Old Apr 10, 2011 | 09:00 AM
BEISSEN's Avatar
The Red opens at 24psi for efficentcy and the Black does not awken until 30+psi the green is sooner then both but makes less power then the red and black.
Old Apr 10, 2011 | 09:10 AM
erald01's Avatar
its all about the spool time and the flow. All the fp turbos have proven to spool pretty quick ( 3500-4000 rpm range) and also flow soo much air. If the spool and flow is dialed in properly then you have a very efficient turbo that can make good power. When it comes to bigger turbos, yes they are great and they flow a lot and make crazy power but your spooling is very slow, meaning you will get lag. But once they start going then there is no stopping them.
Flow is what makes the power and spool is what gets you ahead of the game to get to that power quicker.
Old Apr 10, 2011 | 09:56 AM
acssa's Avatar
something to watch out.... check the design if the BW EFR wheels and FP wheels.... looks very similar.... and fp has been using that design for some time now... the fp guys understand air flow in turbos.
Old Apr 10, 2011 | 10:00 AM
My03evo's Avatar
My black pulls like a **** haha deff does have lag tho
Old Apr 10, 2011 | 10:12 AM
how much power did you make on the black and on how many pounds
Old Apr 10, 2011 | 07:30 PM
My03evo's Avatar
From what I was told it made 641hp on 40psi at DG motors dyno in NY (now running at like 25-30psi) and I just changed some stuff and upgraded to S2 cams. Some say they fiddle with the dyno correction factor to read higher, I really dont know if true or what, he did do a good job tuning it though but either way it was makin some good power....I can post up a vid but dont want to hijack the thread or start no fights because theres a 7 page thread on the car (from previous owner) and some guys might bring the subject back up and turn into another locked thread haha
Old Apr 10, 2011 | 10:15 PM
you think gsc s2 272/275 cams would be a good form to use?
Old Apr 11, 2011 | 08:11 AM
My03evo's Avatar
I heard nothing but GOOD things about those cams so I got a set....if you want em I can get you a great price on em. But for the Best cams I heard BR cams to be the best
PHILLY EVO
Sep 9, 2016 04:16 PM
IRISHEVOX
12
Jan 9, 2014 04:15 PM
stck_trbo_mnstr
Mar 28, 2012 09:53 AM
JDM EVO PANAMA
Oct 10, 2010 11:54 AM
sw20
Sep 20, 2010 06:36 PM
