fp black... bb fp red.... bb fp green
Old Mar 27, 2012 | 11:45 AM
stck_trbo_mnstr's Avatar
ok so i have a non bb fp black right now on my car, but i got some tax money and i am doing a bunch of stuff to the car. gsc s2 cams, full blown double pumper, new clutch. Basically i want some advice as to which set up to go with. My goal is to be right around 550 whp. Which of these 3 turbos should i go with. Should i sell the fp black and egt one of the other 2??? or just stay with the fp black??? remember this is on a stock bottom end and i do not want more than right around 550
Old Mar 27, 2012 | 11:48 AM
evo 9 guy's Avatar
There is no point in wasting money to get a different turbo if you already have the Black. Just keep that turbo and depending on the fuel, tune/have it tuned to the numbers you are comfortable with. Unless you are wanting faster spool of course, then go with a Red.
Old Mar 27, 2012 | 03:22 PM
caLi4G63's Avatar
the more important question is - what do you do with your car (what's your goal)? drag race, road race, daily driver? ask yourself this question and you'll find your answer.
Old Mar 27, 2012 | 03:25 PM
Graphic's Avatar
Save yourself the money and buy the STM walbro 400 kit instead of a 500 dollar double pumper.
Old Mar 27, 2012 | 03:34 PM
MaLo EvoVIII's Avatar
I see you are already making 520 hp. From reading your post I took into consideration two things.
1.) FP Red and Black can both support 550 hp.
2.) You are on the stock block.
I would go with the turbo that can make the power and be more friendly to the stock block (in this situation). In other words, the turbo that keeps the torque numbers lowest. I assume it would be the FP Black.
However, if you have a specific purpose for your evo or want it to spool quicker then I would have to reconsider.
Old Mar 27, 2012 | 03:45 PM
EvoIIIAj's Avatar
Extra money and you're already making 520WHP? I'd get a block built..
Old Mar 27, 2012 | 07:54 PM
gpfury86's Avatar
^^^^^ This...... It won't matter which turbo u have or want with a rod sticking out of your block......
Old Mar 27, 2012 | 08:05 PM
Dmav1989's Avatar
I triple dat..it's not gonna be too much diff between the bb black and jb black, maybe some spool but u already have a black so it would suck if u spent the 2500+ on a bb black and the s2 cams(badass cams btw) and then lose your block cause a rod went through it and then you have to spend more on a built block and you have no core which would cost more..that way you build it and can really push the black jb and make those numbers
Old Mar 28, 2012 | 09:53 AM
thanks guys for all the help.
ant_turbo
Mar 18, 2017 03:19 AM
evokun
12
Aug 3, 2014 05:41 AM
J_Heath
Jul 30, 2014 07:32 AM
Android4g63
19
Mar 10, 2012 01:50 AM
agiaquinto
Apr 14, 2011 05:43 PM
