6262 vs 6265 turbo ?
There is a difference between the 6262 and 6265, not that bad but unless the car sees the track all the time, stick with a 6262.
Hi Guys
One thing that I have been picking up more and more of late with regard load simulation on Dyno results:
We Dyno all our cars in 3rd gear inertia run to get our Dyno Graphs... (Consistant and repeatable results)
Lot of other Tuners try to simulate load and dyno in 4th gear this allows the car to spool quicker and make more boost (Not always Consistant and repeatable results)
If you compare power and spool on various loaded runs the results are very dependant on the dyno operator so somtimes spoolup can be misleading...
65 will be the larger heavier exhaust wheel and on the street there will be a difference especially wrt boost recovery during gear changes etc and spool in lower gears. There is also an optimal size exhaust wheel for a 2L 4Cyl street car with limited rpm band and I believe the 62 is pretty close to the limit of that...
SmurfZilla
63
Sep 14, 2012 10:08 PM
InsaneSpeed
Oct 26, 2011 09:14 AM
ForcedPerformance
159
Mar 9, 2010 11:36 PM
AWD Motorsports
50
May 30, 2008 11:25 AM
Wonder what a/r sizes we're looking at...
