downpipe dilemma... used or new?
Old Apr 14, 2011 | 10:01 AM
taylorgang's Avatar
1st off... searched for a few hours and couldn't really get the info I needed so I'm coming here...
I found a used helix downpipe locally for $70... I believe they're around 300 new... already has the o2 bung welded for o2 sensor so that would save me a bit of a headache... but I also saw a brand new Tanabe downpipe for $120 from evasive... should I just spend the extra $50 and get a brand new one? I don't want to encounter any problems with the downpipe... but I also saw that the tanabe is 2.75 inches and the helix is 3 inches...
any help?
also, I'll be ordering a megan racing testpipe soon, and if I ended up getting the tanabe downpipe I would just order the testpipe with the o2 bung welded on
Old Apr 14, 2011 | 10:07 AM
TJPhillips36's Avatar
I would go ahead with the used one. Their is nothing really special about a downpipe as long as it hasn't been modified or dented.
Old Apr 14, 2011 | 10:34 AM
stackhouse's Avatar
If youre doing a downpipe, might as well go with a 3". Like dude said above, used is fine. Its just a pipe, really. Its not going to wear out or go bad. And if your lucky you can find one thats already set up for wideband. Just make sure on used that you do check to make sure the welds and flanges are not boogerd up. Dents are more of an aesthetics thing.
Old Apr 14, 2011 | 10:39 AM
Slobwalker's Avatar
You can try and see if Cobb has any left. I just picked up one of the few left for $140 shipped and its new with excellent fitment...
Old Apr 14, 2011 | 10:43 AM
javicracer's Avatar
dp is not a wear and tear part, like others say as long is not dented youre fine, also try to get a 3''.
Old Apr 14, 2011 | 11:23 AM
taylorgang's Avatar
aright thanks a lot for the replies... sounds like ill be picking up the used helix pipe then. it already has the 02 bung welded and from what I've read the helix is a true 3" pipe
Old Apr 25, 2011 | 10:14 AM
EvilEVO800hp's Avatar
dents can restrict exhaust flow and slow spool!
evostang
Evo X How Tos / Installations
33
May 16, 2019 03:22 PM
stock_evoIX
Jan 31, 2016 06:40 AM
ThaoDao
Jul 7, 2014 02:32 PM
mrm95
Jul 3, 2013 10:24 PM
tsidrift1
Feb 3, 2012 02:58 PM
