Swapping Turbine housing on gt3071r
Old Apr 20, 2011 | 06:55 AM
SethChef's Avatar
I was wondering if anyone has swapped to a .82 a/r or 1.06 a/r turbine housing on a gt3071R. I was thinking about switching to the t4 .82 a/r so I can also use the V-band exhaust fitting and fit a new exhaust manifold that I just purchased. Any info helps, thanks for looking.
Old Apr 21, 2011 | 10:22 PM
SkipDMan's Avatar
If you have a 3"turbo back exhaust and you are running a healthy amount of boost, you should swap to the .82. In these conditions, contrary to popular belief, you will see better spool and more top end with only a slight loss in torque before the turbo begins to spool.
Old Apr 23, 2011 | 11:07 AM
SethChef's Avatar
Yea, I have a 3 in exhaust from the turbo back and I plan to push about 30 psi if all goes well, thanks for the input, hopefully I'll have it swapped by the 10th or so next month.
Old Apr 23, 2011 | 01:10 PM
blkmkIII's Avatar
why not just buy a better t3 turbo? Maybe a little research would help also.
Old Apr 24, 2011 | 08:44 AM
SethChef's Avatar
The turbo is in good shape and I like the response, but my current manifold is cracked and the new manifold is for a t4 turbo, the turbine housing is like 300 whereas a new turbo is like 1500 or so, I figured swapping housings would be more cost effective.
Old Apr 24, 2011 | 09:59 AM
BEISSEN's Avatar
Where in VA are you? I think the Houseing switch is much better then a new turbo lol. Also look at FP they might do more then a Houseing and also a little more $ and its a HTA turbo which is allot better.
Old Apr 24, 2011 | 07:29 PM
SethChef's Avatar
I may see what they can do as far as a rebuild, it depends on how everything looks when I pull the turbo to put on the new housing and exhaust. I live in Gloucester.
xJLCx
May 30, 2016 09:49 PM
Poloiceberg
65
Jul 16, 2013 06:40 PM
pwerks
38
Sep 21, 2009 08:42 PM
antilag_200
10
Mar 11, 2009 04:12 AM
EVO8URV8
14
Oct 22, 2006 06:45 PM
