EVO 11.5 Hotside, anybody try it?
Old May 6, 2011 | 12:53 PM
  #61
wshihdnevo's Avatar
Will someone with more $ than me please test this!
Old May 6, 2011 | 01:16 PM
  #62
BLKCarbonEVO's Avatar
Ramses, you are that poor???
Mikey
Old May 6, 2011 | 02:43 PM
  #63
wshihdnevo's Avatar
Mikey
Since January, yes...ask me why...
Old May 6, 2011 | 04:16 PM
  #64
Why
Mikey
Old May 6, 2011 | 04:18 PM
  #65
wshihdnevo's Avatar
Why
Mikey
Got married... But yeah, if I had a little extra $ I would swoop this up. Might try and save a little to test it out in the next few months or something.
Old May 6, 2011 | 04:38 PM
  #66
CONGRATS MAN!!! I have been trying to get married the past 3 years. Just to busy lol
Mikey
Old May 6, 2011 | 05:39 PM
  #67
wshihdnevo's Avatar
Mikey
Thanks Mikey! I love it! I get mostly what I want for the evo, but not as much as I did before we got married... Its prob a good thing though.
Old May 12, 2011 | 11:12 AM
  #68
wshihdnevo's Avatar
Here is this pic bigger so everyone can see it;
Old May 12, 2011 | 11:36 AM
  #69
SyZyGy1394's Avatar
interesting....subscribed
Old May 12, 2011 | 11:41 AM
  #70
SyZyGy1394's Avatar
It would be **** if someone casted something like this with a 3 inch outlet and also a cast o2 housing to match. I bet it would sell like hot cakes...
Old May 12, 2011 | 07:02 PM
  #71
sparky's Avatar
Judging from the pics I have seen, this piece looks very nice. Has anyone sent one into Forced Performance to have it cut for the Red, or Black's turbine wheel? Or has anyone had one cut for the HTA Green's turbine wheel yet?
Old May 12, 2011 | 07:06 PM
  #72
sparky's Avatar
I really like the fact that the flapper valve on this 11.5cm unit is larger diameter than the factory 10.5 single puck flapper valve. The factory flapper does not allow for much enlarging of the wastegate bypass ports.
Old May 13, 2011 | 06:46 AM
  #73
That is correct. I tried to enlage my ports by 8mm and ended up having to make a larger flapper. You really can't port much at all on the stock flapper.
Mikey
Old May 13, 2011 | 05:33 PM
  #74
94AWDcoupe's Avatar
larger flappers blow open easier than small ones. there is spool speed loss with early lift.
I would be worried about material . the divider wall breaking off will ruin your day.
Old May 13, 2011 | 06:41 PM
  #75
sparky's Avatar
Originally Posted by 94AWDcoupe
larger flappers blow open easier than small ones. there is spool speed loss with early lift......
I just don't agree with the above statement. Why would this be true? Substantiate your claim.
Given identical wastegate bypass port diameters I would tend to disagree with this. In the first place the larger diameter flapper valve would weigh more than the smaller diameter valve, given the same metallurgy. Wouldn't it?
A higher mass flapper valve would be more difficult to lift given the same seat pressure.
