Surge Tank Setup...
Old Apr 22, 2011 | 02:17 AM
silentkiller's Avatar
Surge Tank Setup...
Is it possible to run just 1fuel filter for a twin external inline setup. Filter run after fuel pump as the twin fuel pump will run into a fuel converter block.
Possible? Any flow issue?
Advise please....
Setup will be in this manner;
2.5L Surge Tank -> 02X EXTERNAL FUEL PUMP -> FUEL CONVERTER BLOCK (2XINLET + 1XOUTLET) -> FUEL FILTER -> LINEs to FUEL RAIL.
Old Apr 22, 2011 | 08:00 AM
n2oiroc's Avatar
thats what i plan on doing, i know its been done before many times without issue.
Old Apr 22, 2011 | 08:08 AM
Highboost26's Avatar
i have a nice surge tank setup for sale .. I only ran one filter with mine .. went 255-->surgetank-->filter-->aeromotive-->rail
Old Apr 22, 2011 | 08:43 AM
n2oiroc's Avatar
im not putting a filter between the surge tank and pumps on the output side, im just letting the intank pump thats filling the surge tank do its job. i will have a pump after the Y though.
in tank -> surge -> 2x 044's -> Y fitting -> filter -> rail
Old Apr 23, 2011 | 05:43 AM
any picture?
Old Apr 23, 2011 | 05:55 AM
Any issue with the flowing ?
btw u run 1 filter?
care to hare what filter?
Old Apr 23, 2011 | 05:56 AM
Any words from top garage to share?
Old Apr 23, 2011 | 06:13 AM
i ran a filter before the pump to make sure nothing goes threw and tears the pump up ..
Old Apr 23, 2011 | 08:56 AM
n2oiroc's Avatar
btw u run 1 filter?
im not done with it. im going to be running a -8 line and this filter after the Y. http://fuelab.com/fuel-filters/828-s...fuelab-filters i see no reason why it would restrict flow, they are made to be ran with huge pumps.
i just got my parts in then i have to send it out for welding.
Old Apr 27, 2011 | 10:58 PM
Thanks for the picture guys....
Old Apr 27, 2011 | 11:01 PM
My tank there only one pump outlet...so im running one filter - 2 x Pump - converter block - fuel rail.
FLOW will have no issue right?
Btw n2oric im getting the same filter as yr
Old May 12, 2011 | 03:47 AM
Guys, do we run the line to fuel reg 1st then to fuel rail or etc?
Old May 12, 2011 | 07:17 AM
CO_VR4's Avatar
THe fuel regulator is commonly AFTER the fuel rail, and essentially acts like a "dam" to regulate the pressure between the pump and the regulator (including the rail).
I'd place the fuel filter between the stock pump and the surge tank, since there's not much line or pressure in that location, and your main pumps would not have to deal with any additional restriction caused by the fuel filter while supplying higher pressure and volume to the rail...
Old May 12, 2011 | 07:22 AM
CO_VR4's Avatar
n2oiroc -- What are you building with those slabs of aluminium -- looks like they are thick enough for suspension parts...?
Old May 12, 2011 | 10:43 AM
Buddy, do u have any pic for this?
I see afews different methond of putting the fuel reg.
Which is best position..
As i now we need to run 1 X line to the fuel rail & 1 X return line from fuel rail back to surge tank...am i right?
