Stripped stud on fuel pump housing.
Old Apr 27, 2011 | 09:05 AM
oldwheelieguy's Avatar
I was replacing my walbro 255 this morning and when I was tightening one of the 8mm nuts down I stripped the threads on one of the studs that holds the ring down. Is there any way to fix this? From looking at it it looks like I would have to replace the tank. Thanks in Advance.
Old Apr 27, 2011 | 09:38 AM
sirsol's Avatar
When you say stripped, how bad is it? Does it thread on normally for some portion of the stud, and then spin freely? I had some of the threads near the bottom of the stud damaged, so I ended up stacking a couple thin washers so that the nut torques where the threads were good. If the entire stud is damaged though, only option may be to leave it off (probably not a good idea, but the rest of the studs might be able to keep it sealed) or you can use a die for external threads (like your studs) to fix the stud. Good luck
Old Apr 27, 2011 | 11:07 AM
Silk's Avatar
Happend to myself as well while I was installing my full blown double pumper. Ended up stripping two and just decided to run with out them, no problems thus far.
Old Apr 27, 2011 | 11:58 AM
well I actually stripped it the first time I put a walbro on and this time I couldnt get the nut off so I had to cut it off and obviously destroyed the stud. Its running fine without it but I would like to repair it if possible. Any ideas? Im not sure whats under the stud because I cant feel the back of it from inside the tank.
Old Apr 27, 2011 | 01:57 PM
Boosted Tuning's Avatar
How are you guys stripping those studs?? I have install many FPs and never had an issue with stripped studs.
Old Apr 27, 2011 | 02:19 PM
Silk's Avatar
In my case I over tightened them because I didnt have my fuel pumps set at the right height. Just a a series of rookie mistakes lol
Old Apr 27, 2011 | 02:27 PM
Rojo EVO's Avatar
One of the studs on mine broke off and it runs perfect without it.
Old Apr 27, 2011 | 02:30 PM
this is what I did, I have installed about 15 of them and this is the first time I stripped one.
Old Apr 27, 2011 | 06:01 PM
sirsol's Avatar
Do you work on cars from the snow/salt belt?
Old Apr 28, 2011 | 12:29 AM
SpoolSwagg's Avatar
ouchh. how bad is it?
Gtizks
11
Jan 5, 2017 08:11 PM
cmillz1225
Jul 14, 2013 07:26 AM
boostnMA
Oct 26, 2012 07:21 PM
lanport
Aug 2, 2006 12:11 PM
Creamo3
Jun 27, 2005 06:09 AM
