Launch help!
Old Apr 28, 2011 | 01:44 PM
mt057's Avatar
You should be at your target rpm. I go for 6300-6500rpm. I am using the 2-step launch so I sit there for a sec or two at that target rpm. Once the lights go you have to release quickly. If you are trying to cut a 60' that is 1.8 or better you don't have much time to be feathering out the clutch. As stated before it need to be a quick controlled motion. I seem to get the best results sort of stutter stepping it out as mentioned. I quickly release the clutch petal out until the clutch begins to engage then pause for a moment before quickly fully releasing. The pause is to keep the rpm from falling off to much.
Old Apr 28, 2011 | 02:23 PM
Srr's Avatar
Srr
any vids? lol
Old Apr 28, 2011 | 03:16 PM
forc3 f3d's Avatar
the only way you are going to understand it is by doing it yourself. after a few tests on your own you should have the feel and that "sweet spot" on your car to get out of the hole quickly.
Old Apr 28, 2011 | 05:22 PM
InitialE's Avatar
Nice description. Makes sense. Thanks.
Old Apr 29, 2011 | 06:23 AM
gidz's Avatar
but okay guys with me trying this am i going to burn my clutch off???
Old Apr 29, 2011 | 08:21 AM
Ian0611's Avatar
You shouldn't burn it too bad as long as you don't feather the pedal real long. As soon as you feel grab let it go. If you do it right the whole thing should only take about half a second.
Old Apr 29, 2011 | 08:31 AM
tim85851's Avatar
launching your car in general will cause your clutch to wear down...if you're worried about wear, dont launch your car...
but if you dont care, just follow the instructions and you will LEARN how your car launches, more practice will get you accustomed to doing it the right way.
so practice, practice, practice.
Old Apr 30, 2011 | 09:41 AM
gidz's Avatar
Ok guys I will post a video on my present launch and then my improved launch!!!
Old Apr 30, 2011 | 12:54 PM
SubieEvoGuy's Avatar
nice, try and get a video of the tach and speedo.
Old Apr 30, 2011 | 12:58 PM
Raptord's Avatar
To minimize wear on the clutch, try not to do too many launches in a row, as heat will gradually build up and it'll wear even faster. I don't do any back-to-back launches.
And I think tim85851 had pretty much the best explanation of how to practice your launch.
Old Apr 30, 2011 | 01:52 PM
bonsuz01's Avatar
To me, You read how to launch, but and then you have to try and practice it's something you have to feel it yourself.
djelliott978
Jul 11, 2016 03:04 AM
bighead87
May 8, 2012 12:51 AM
nikkadanny
Apr 11, 2007 07:48 AM
EvoDan2004
Apr 5, 2007 05:47 PM
Luke WL.
Driving Techniques
May 20, 2005 03:19 PM
