Shifting Problem, Had this problem for a LONG time.
Old May 4, 2011 | 02:12 PM
Johnboy1065's Avatar
Hey,
I have had a problem getting my car into gear for a long time, years actually.
Well, last racing season I broke my transmission. So I sent it to shep for a total fix/rebuild. He also put new synchros in the tranny which I thought might fix the problem.
BUT, I got it back and the samw symptoms occur.
Car shifts fine in and out of every gear if you just sit there with the clutch in not moving.
but when you start moving and go from 1st to 2nd or any other gear it is really notchy to get into gear.
Is it possible that motor mounts are the problem? I have a new clutch, new tranny, I even bought new shifter links to try and cure this problem.
ANY input will help.
thanks,
John
Old May 4, 2011 | 09:45 PM
anyone ever heard of this? SPEED dependant lock out?
Old Sep 11, 2012 | 10:04 PM
Still having this issue. any opinions?
Old Sep 12, 2012 | 01:50 AM
evilempire76's Avatar
Have you tried properly adjusting your clutch? Follow this:
Old Sep 12, 2012 | 09:03 PM
yeah I have followed this. my clutch setup is somewhat different though because of the quartermaster using a hydrolic throw out bearing.
I have put the car in first. held in the clutch and revved the car up to around 7000 rpm's though and it doesnt seem to be dragging.
Old Sep 12, 2012 | 09:04 PM
anyone think it could be a tranny fluid issue?
I'm using 100% redline lightweight shock proof in it. Wonder if I were to mix it if it might help?
Old Sep 12, 2012 | 09:44 PM
Thore's Avatar
I've noticed some people saying to not run straight lightweight shockproof stuff as it is too light for our applications. They mentioned mixing 1 bottle of that with 2 bottles of BG Syncromesh.
I've had pretty good luck with "Redline Cocktail" http://www.maperformance.com/redline...smissions.html
Try that and see if it does any better. If not, at least you have the correct fluid and can move on to other potential causes. Your typical part store should have those in stock.
Old Sep 12, 2012 | 09:56 PM
fastyouth1313's Avatar
saved for the video
Old Sep 13, 2012 | 03:22 PM
thechriskarel's Avatar
OP I feel your pain. this plagues the 8th gen Si Civic, and I don't want it on my next car (which will be an Evo) at all. I hope this isn't common on Evos.
Old Sep 13, 2012 | 03:27 PM
89turbosupra's Avatar
i had a similar notchiness when trying to go into gear and i switched to amsoil mtg and the tranny shifted like butter afterwards. the problem returned a little while after but due to a totally unrelated problem involving a bad slave cylinder.
Old Sep 14, 2012 | 08:09 AM
RawrImAMonster's Avatar
It is. Evo's are known for notchy transmissions. Mine is a pain to get into second in normal driving. Shifts fine at WOT, just not under normal driving.
Old Sep 14, 2012 | 09:49 PM
Thore's Avatar
I purchased my car with 20,000 miles on the odo. 2nd has already given me trouble. It will always go in but not without grinding, or a slight crunch unless I shift real slow. I've been through Amsoil, Redline and OEM with no success. Just nature of the beast I guess.
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
06redrocket
Mar 22, 2010 06:14 PM
sekula
Aug 3, 2009 07:08 PM
Wicked White
Mar 17, 2007 07:08 PM
KazzEvo8
11
Sep 12, 2006 08:53 AM
