Sandblasted Valve Cover Problem
Old May 17, 2011 | 05:18 AM
tsidrift1's Avatar
He could get a new one, but whats that gonna do, he still wants it powerdercoated. It still needs stripped right??
Yea, I have little bolts holding my baffles back on. I used red loctite on them. Yes they are exposed to heat, vibration, etc. Just like any other damn bolt on the motor lol.
Old May 17, 2011 | 06:28 PM
Midnightevo8's Avatar
So I just tapped them out with a 3/16 drill bit. There was quite a bit of sand underneath the baffles and I could see how that would have been a problem if I wouldn't have caught this before I installed it on my fresh motor build. I guess the next step will be to clean it as good as I can. From what I hear baking soda and other degreasers sound like the best bet. As far as reattaching the baffles go I will probably go the route of using small bolts and red loctite since some people say that you arent able to weld them back on.
Old May 22, 2011 | 04:44 PM
UPDATE: We installed the valve cover with bolts and used red loctite on the bolts and they seem pretty sturdy. I'm probably not going to be running for a permanent fix. I'll probably order a valve cover and have it redone. Looks like this time I will be stripping it with a chemical base. Whats the best way to strip the oem powder coat?
Old May 30, 2011 | 10:29 PM
Murf's Avatar
to remove paint from valve covers use a good quality aircraft paintstripper.
http://www.tcpglobal.com/autobodydepot/paintremove.aspx
apply with brush let sit, use plastic scraper, then wash with water.
Old May 31, 2011 | 08:29 PM
THUB's Avatar
I almost want to subscribe to this so I can read about somebody trying to weld the baffles back in
Old May 31, 2011 | 09:03 PM
rodent's Avatar
I've had good luck with this stuff when I remove the powder coat from my wheels:
O'reilly and Advance auto usually carry it. I've tried other brands and they all suck.
Old Jun 8, 2011 | 01:12 PM
Scsilver2's Avatar
/good stuff there,just make sure you are ventilated!
Old Jun 8, 2011 | 02:33 PM
rodent's Avatar
Yep, its nasty stuff. Just the vapor and any over spray will burn your skin / eyes. Use safety glasses and oven cleaning gloves. Stuff burned through my thin blue rubber gloves.
Insanity Evo
Jul 8, 2015 01:24 PM
05ah8james
20
Mar 20, 2014 11:33 AM
skatermsmn
22
Mar 28, 2013 03:24 PM
wrxedout
May 28, 2011 07:49 PM
JDMevoBOOST
25
Dec 12, 2008 12:47 AM
