Use vag coil with Aem ver1
Old May 19, 2011 | 12:18 AM
flandrs's Avatar
Is there anyone who does run with aem ver1 and vag coils??
If so how did you set them up in the software??
I have been reading out that the vag coils should have MAX 2ms dwell over the whole map.
And i´m not really sure how to setup all settings, i tried once but then the coils burned up.
Now i don't want to burn my new coils, so it would be great if someone could help me.
I also read on aempower forums
check between pin 2 and 3 (this is the Spark Signal Input and Ground).
if Less than 500 ohm resistance use 5V PULL UP route(falling edge signal)
if Greater than 1k ohm reistance use Ground switching(rising edge signal)
And my coils is 1k ohm + so they should have rising edge signal.
But the rest is a big ?
Old May 22, 2011 | 02:34 PM
flandrs's Avatar
nobody knows??
Old May 22, 2011 | 02:47 PM
mrboost05's Avatar
try posting this in the ems fourms there is a aem specific one and someone who really knos it may be able to help you good luck.
Broke4speed
Aug 6, 2017 07:57 PM
Ant1
Apr 3, 2016 11:05 AM
DuffmasterFresh
10
Mar 17, 2013 10:49 PM
Raheelq
Dec 12, 2009 11:59 AM
pumpdog720
Sep 7, 2005 07:05 PM
