Evo VI vs Evo 8/9 transmission half shaft spline differences
Old May 20, 2011 | 09:24 PM
CrunchyMilk's Avatar
Evo VI vs Evo 8/9 transmission & half shaft spline differences
I have an Evo VI transmission that I am using for a project but Evo VI half shafts are in short order in the states. Shafts for the 8's and 9's are much easier to find.e Does anyone know if there is a difference between the output splines in a VI vs. an 8/9 transmission?
If the two are different does anyone know if the outputs are interchangeable. I have no problem rebuilding the transmission with current parts. Worse case is I import shafts from JP or the UK.
Thanks in advance.
Old May 21, 2011 | 04:05 PM
94AWDcoupe's Avatar
The shafts are the same part evo 4-9
Old May 21, 2011 | 07:13 PM
Thanks for the reply. That makes sourcing parts much easier for me.
I have seen that the shafts are different lengths throughout the model years so I will be mindful of that when I buy.
Are the splines at the hub end the same for all models 4-9 also?
rictrd
Aug 20, 2015 02:48 PM
boostn4
Aug 12, 2015 12:34 AM
kongenjk
Jul 30, 2014 09:29 AM
tbryant0226
Jan 13, 2014 07:51 AM
evodave
Evo 'For Sale' Exterior Styling
980
Jan 17, 2012 11:53 PM
