Car randomly dies?
Old May 23, 2011 | 04:18 PM
LakerRaider's Avatar
Car randomly dies?
Hey guys,
my I finally got my evo ix back after 2 weeks in the body shop. the day after, when i was pulling into a parking spot with no clutch or throttle, my car died, but with power still on. It happened so smoothly that I didnt notice until my wheel got hard to turn. I turned it on immediately. 5 days after, today, I was pulling out of a parking spot, but when i put it in neutral, my car di the same thing. Engine off, power on. I immediately try to turn the car on but it would just crank for a while and not turn on. I got a jump, but even then, it cranked for a while, then slowly turned on, and stayed on as I gave it gas. The car then drove fine, and turns on after being off.
This problem has only happened twice, but is too risky to let slip by...plugs are fine, about to check my battery. Sidenote: since I got my car back, the two orange corner lights do not come on, and I hear a weird high pitch quick noise that seems to be coming from the glove box area. Any ideas are greatly appreciated!
Old May 23, 2011 | 04:19 PM
mods are cossie m2, FIC 1050, walbro, 3 port ebcs, bolt ons, tune, etc.
Old May 24, 2011 | 08:17 AM
ttt
Old May 24, 2011 | 06:04 PM
Thanks for the help all 0 of you lol
Old May 24, 2011 | 06:20 PM
NewEvolutionIX's Avatar
What did the body shop do to your car?
Old May 24, 2011 | 06:59 PM
johnstonj's Avatar
mine does it when i dont let it warm up bc of the cams
Old May 24, 2011 | 08:33 PM
What cams do you have? Does it bog or shake when it it dies? And does it always turn on right after or do u have trouble getting the engine to start again?
Old May 24, 2011 | 10:28 PM
Replaced my front bumper, ets intercooler, the fan right behind it, the AC condenser, and the oil cooler
Old May 24, 2011 | 10:30 PM
Not that any of the parts were broken, because the car was still fully drivable, but they replaced anything that had and slight bends or damage
Old May 25, 2011 | 01:01 AM
awdordie's Avatar
X2 for the cam issue. Mine does it everynow and then, and also will have a little trouble getting back started takes it a little longer to crank over. Also if I go in the store or someplace really quick and the motor is still at operating temps it wants to take its time cranking over. When its cooler tho it fires right up.
Old May 25, 2011 | 10:46 AM
ashwill's Avatar
I am not an expert but check into your power distribution and wiring. He did mess with your fan. If it was fuel it would probably shake and vibrate then cut off.
Old Apr 19, 2012 | 02:31 PM
shadovarian's Avatar
My 2005 evo is doing this. I will sometimes just let off the gas in neutral and then the car will die and not want to restart for a few minutes it just cranks. My logger loses contact with my ECU as though the ground has been dropped but everything else seems to be working (gauges etc)
First of all which ground is for the ecu so I can check it? I have re tightened all grounds I found under the hood.
Second, could my turbo timer be causing this? I just turned it off to see if it still occurs
Old Apr 19, 2012 | 02:39 PM
bbyevo8u's Avatar
maybe you MAF got dirty at the body shop
Old Apr 19, 2012 | 03:17 PM
OP probably got his car fixed quite some time ago. I still need help though. I can't imagine my Maf would cause the ecu to not get power.
Old Apr 19, 2012 | 05:18 PM
bbyevo8u's Avatar
oh damn i didnt see that.. seems like you might have a bad throttle position sensor
