Please help heavy vibrate on accelerate
Old Dec 7, 2013 | 05:17 PM
MyronGainz's Avatar
Originally Posted by Big Lex
Re vibration. My evo is casing me pain. as i accelerate up to 5-6 rpm the entire engine vibrates so violently that it cause my ac pipe to break. the sound is coming from the engine room. but cant pin point the exact location. i recently change the timing belt. the car runs fine when driving at lower rpms.
I can almost guarantee that your timing belt was installed incorrectly. The marks on the oil pump sprocket will line up, but if the balance shafts are not "in phase," you will experience the problem you are having.
The solution is to rotate the oil sprocket three times at the very least, until when you rock the sprocket (as in move it forward or backwards slightly), the timing mark "falls back" onto the mark on the block.
Good luck
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
kwinters
Lancer Tranny/Drivetrain Tech
10
Nov 16, 2017 04:20 PM
ugakirk
76
Jul 22, 2016 05:15 PM
usacchamp
Jul 27, 2015 06:41 PM
xf06
Jan 5, 2012 10:20 AM
