help with i/c piping
You honestly get what you pay for in this area. The LICP will give you the most hp. I would look into getting an ETS v2 LICP and save up for the ETC UICP.
That is my 2cents. Take it for what it is worth.
Mikey
If I'm gonna go ahead and pay the money how bout buscher? I have a friend who knows david and absolutely swears by everything he makes.
I appreciate all the input you guys!
Mikey
id say if 400 is all you got to work with man, id say get a credit card, buy your etc licp and short route uicp, and the rest of the money spend on a relocation kit and put the battery in the trunk. That way no mini battery hiccups that those things can have, and youll relocate weight to the rear, black carbon was right the only improvements on the uicps are short route ones, im runnin an ets, and compared to stock vs some other stock route uicps it shaves off about 2' of piping which leads to increase spool up time etc....so theres my recommendation
The main reason for replacing the upper intercooler pipe is to remove the factory rubber hoses. These hoses have a tendency to blow off once they become oil soaked and weathered. The upgraded upper pipe w/ silicone couplers and t-bolt clamps is a great way to make sure this doesn't happen. It also helps with throttle response since the factory hose balloons under pressure.
We have a ton of piping options to choose from.
http://www.extremeturbosystems.com/E...cooler-Piping/
Stock Battery, Mini Battery, Magnus, Titanium... etc.
Thanks!
Michael
Thanks!
Michael
Get an intercooler hose kit from Samco, Forge, etc., add t-bolt clamps and 400 hp should be no problem. I'm assuming you already have an aftermarket licp or you wouldn't be in that range hp.
Thanks!
Michael
Thanks!
Michael
Mikey
I forgot to mention the lower pipe is a great way to gain some horsepower and throttle response if you haven't already upgraded this.
If you have a minute take a look at our lower pipe page.
http://www.extremeturbosystems.com/E...oler-Pipe.html
This shows the gain vs stock.
Thanks!
Michael
Thanks!
Michael
yea listen to the guy with 5 posts...haha, cheap only gets you so far, and besides man if your not aware most lower intercooler pipes including mine are a 2 piece unit, which means usually the coupler in between the pipe off the outlet, and the pipe to ic, usually tears or breaks from rapid movement from air etc, the ets is a one piece unit which means less money n headaches on torn couplers. cant wait till mine comes in, goin wide tank and v2 licp.
