help with i/c piping
Old May 29, 2011 | 02:58 AM
MarineEric's Avatar
Ok so trying not to sound like a cheap *** here but what's the best bang for my buck on a full hardpipe kit for circa $400. I have a stock battery btw
Old May 29, 2011 | 03:01 AM
Pal215's Avatar
Quick reminder, you get what you pay for. Sometimes the stock piping is better than cheap aftermarket pieces. Take your pick: http://www.maperformance.com/evo-vii...cooler-piping/
I personally run ETS piping, love the fit and quality.
Old May 29, 2011 | 03:04 AM
MarineEric's Avatar
the reason I want it is because I'm starting to wear a hole in the rubber elbow near the radiator fan. Any thoughts on injen? They have a full kit for under 4. Is it legit?
Old May 29, 2011 | 03:10 AM
justastockevo's Avatar
why not to buy an ebay licp (they're virtually all the same) and keep stock uicp?
buy another elbow from dealership and call it a day. you get best battery/filter fitment as a bonus.
Old May 29, 2011 | 03:15 AM
MarineEric's Avatar
Cause this things a handful of small parts and a tune away from bein a 400hp dd and I don't want to shred another elbow or blow it up usin ebay piping lol, she's already got enough problems lmao
Old May 29, 2011 | 03:17 AM
MarineEric's Avatar
Plus stock uic doesn't look very clean either
Old May 29, 2011 | 03:21 AM
Pal215's Avatar
Replacing the uicp yields no gains, but i just did it for the hell of it. You can save yourself some money and not do it, if rubbing is an issue, adjust your uicp.
Heres my setup:
Fitment is spot on, no more stock coupler rubbing on radiator fan.
Old May 29, 2011 | 03:23 AM
MarineEric's Avatar
So only the lic piping yeilds gains if changed?
Old May 29, 2011 | 03:26 AM
Pal215's Avatar
injen works, but i dont like that kit because the piping tappers.
Old May 29, 2011 | 03:28 AM
MarineEric's Avatar
God I hate bein a broke ***** haha
Old May 29, 2011 | 03:29 AM
MarineEric's Avatar
What about weapon r? No bueno?
Pal215's Avatar
In most cases yes, unless you replace your uicp with a short route kit, which would at least improve throttle response. Bottom line is, you want to have less coupler and more solid piping. I dont like how the factory uicp couplers expand under boost.
Old May 29, 2011 | 03:32 AM
MarineEric's Avatar
Well havin that hole in the elbow is causing boost leak like its cool so either way it needs to get fixed soon
MarineEric's Avatar
Your setup looks clean as hell btw
Old May 29, 2011 | 03:33 AM
Pal215's Avatar
You need a small battery kit for the weapon r piping
