Increasing actuator preload??
Old May 29, 2011 | 07:46 AM
Evo8uk's Avatar
Is there any negatives to increasing the preload on the actuator I'm currently running a hallman pro at 26psi? At this level of boost with the hallman would I benefit from a uprated actuator?
Old May 30, 2011 | 08:01 AM
sparky's Avatar
Huh, this one almost slipped under the radar!
Is your car totally stock? If not, then please post up your complete list of power mods. For starters: what turbo, what actuator(eg: stock VIII 16G, stock VIII actuator?) Also, what diverter valve?
Old May 30, 2011 | 08:03 AM
sparky's Avatar
Have you played around with the wastegate spring pressure(preload) at all yet? Or is it as delivered from the factory?
Old May 30, 2011 | 08:10 AM
sparky's Avatar
So you are on the stock actuator. Don't fix it if it ain't broke. I think that you should try increasing spring preload with the stock unit before plunking down money on an upgraded one.
Old Jun 1, 2011 | 11:43 AM
Evo8uk's Avatar
It's a VIII with a 10.5 exhaust housing, cams, walbro,3" exhaust currently on stock actuator using a hallman pro running 1.75bar boost but lately the boost is tailing off a little more than usual should I be running more than standard preload at these boost levels or maybe a updated 1.2bar actuator?
EvilDSM97
Feb 2, 2017 10:51 AM
4G63_EVO
Aug 20, 2016 08:55 PM
Kian
Jun 13, 2013 07:52 AM
kouzman
Apr 3, 2008 04:35 PM
joshd
Mar 21, 2006 11:55 AM
