Possible bad synchros? Or what else could it be?..
I tried searching for possible symptoms of bad synchros but I didn't come across my issue anywhere.
When downshifting in to any gear, it shifts in to the gear just fine, but when I am releasing the clutch that a pretty loud whine/rubbing sound happens until it is completely in gear. If I rev match while downshifting, this sound doesn't hapeen. It also happens quite frequently when releasing the clutch intially in first gear.
Any possible leads? I had an exedy twin hd installed back in January, car has ~58,000 miles.
its not the clutch, because it didn't do it as bad at first, and now 4000 miles later this sound is becoming worse and worse. Also, it did it some before the twin was installed, and has just increased severity over time.
This also rules out that it just needs to be bed in, it has definitely had its time.
and no, thats the weird thing. like say im coasting in neutral then it needs to match up to say 3000 rpms, it will make this noise. But when getting on it and slipping it between shifts, say from 5000 down to the same 3000, it won't do it.
alsong2002
Mitsubishi TC-SST Discussion
Jul 12, 2016 08:11 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
porsherules911
Jun 12, 2010 08:30 PM
