FP Red Owners with 2.3 or 2.4 engines please reply
Old Jun 8, 2011 | 09:08 AM
Hardware's Avatar
Originally Posted by Fast_Freddie
I have a 2.4L with an FP Red, I am putting down 550hp 500lbft on Virtual Dyno... I really need a new intercooler as it is choking out the set up... It pulls hard and is great for a daily driver...
What FMIC are you running?
Originally Posted by BLKCarbonEVO
Yes you can convert the Red to a Black for 1k. The Black is saver on the stock motor too. Tq is usually loser and makes more power. The stock motor is not scared of power, just tq. Keeping the tq below 420-425 will be a fun ride. A black can make 500whp at that tq level on the stock motor. That is prob my favorite stock motor setup, period.
Mikey
Thanks for this answer. I don't have a good core so for the price of a 2.0 and Black Upgrade I'd rather have a 2.4 on Red. Seems to make more sense for my situation.
Old Jun 8, 2011 | 09:18 AM
BLKCarbonEVO's Avatar
Freddie is running the Injen 3.5 FMIC. He will be going to the 3.8 Garrett core very soon
np, it is up to you what you want to run. a lot of times the extra 20% of VE that the 2.4 flows tend to make the Red fall on its face in higher rpms. Really depends on the fuel and power level. The Red on the 2.4 will have a decent power band till you break 550whp then it will start to choke up top. It takes a lot more to choke a black in higher rpms. If you look at my power band, it is still keeping up with the motor at 8500rpms.
If you go 2.4 make sure you get some large cams to compensate for the extra 20% of required VE. I had HKS cams prior to my Custom GSC cams and I realized how bad the HKS cams were choking my setup. below is a direct before and after of the cam swap. 150+whp at 8k rpms.
Attachment 338718
Josh, I just realized that I should have re-read my post above... There were a lot of errors.
Old Jun 8, 2011 | 09:23 AM
soon2bEVOIX's Avatar
WOW! The differences in the graph are from cams alone>>>??
Old Jun 8, 2011 | 09:38 AM
Fast_Freddie's Avatar
Veteran: Navy
Correct running the Injen intercooler that was on the car the day I bought it, however it is more like 3.2"... has been a good cooler for the most part, just outgrew it with this set up!
Old Jun 8, 2011 | 09:43 AM
Yes, just the cams. All about the right combo man
Mikey
Old Jun 8, 2011 | 10:43 AM
RockmanX's Avatar
Yes, just the cams. All about the right combo and plenty of money man
Mikey
Corrected that for you big dawg
Old Jun 8, 2011 | 10:52 AM
SmurfZilla's Avatar
I spoke to Aaron about their Cam specs thru GSC and he told me if I already had the S3's to keep them.
Old Jun 8, 2011 | 11:00 AM
Mikey
Amazing! I'm guessing cams on my setup wouldn't yield that much gain. Since I have a FP Red and stock 2.0. But it is def encouraging that cams open these motors up so much.
Old Jun 8, 2011 | 11:32 AM
The S3s and my cams are fairly close... To my knowledge there has not been a direct back to back yet, but I would think power levels to be close. My cams have a bit more lift and a lot higher ramp rate which is great for spool and cleaning out the cylinders with fresh air quickly. If you noticed, when I went from the HKS to the my GSC cams, I didn't lose any spool... If I had done S3s the max power may have been close but I would have lost spool. I enjoy my cams.
Also Greg @ GSC has a hard time getting the blanks large enough to make my cams. That is why they reccommend the S3s.
Mikey
Old Jun 8, 2011 | 11:35 AM
Erik@MIL.SPEC's Avatar
So what cams would you recommend for a 2.3 + FP Black? I was thinking the s2's would do the trick. I'd do a 2.4, but I have some MIL.SPEC rods and MIL.SPEC 2.3 stroker pistons sitting in my hands...and they need a good home
Old Jun 8, 2011 | 11:43 AM
ta ace's Avatar
Originally Posted by RockmanX
if all your going to do is drag race get the fp black and call it a day. dont waste money on the fp red.
alot of people that go from red to black wish they kept the red
i loved my red street monster!!!
Old Jun 8, 2011 | 12:05 PM
Eric, if you do a 2.3 or 2.4 I would reccommend the S3s 100%. You are using a motor requiring 15-20% more airflow than a 2.0. So the larger the cam the better. The S3s on a 2.3 or 2.4 idle just like a S2 on the 2.0. Just to show you the VE difference between the two motors. Larger motors can get away with larger cams. I think an S2 is to small for a stroker. They are choking the motor in higher rpms.
Mikey
Old Jun 8, 2011 | 12:16 PM
94AWDcoupe's Avatar
hes like a broken record posting that supposed 150hp gain from cam swap. no where else will you find such gains. not even close. look up the AMS cam testing. from stock cams to the best didnt gain anywhere near 150hp. there was something amiss in his setup at the time.
Old Jun 8, 2011 | 01:26 PM
Ok, for people who have run both a Red and a Black on a stroker, what are the differences in transient response? I'm asking because I know Aby didn't like the Black as much below 4,000 rpms. Wasn't peppy enough for him in day-to-day traffic on his 2.3.
Old Jun 8, 2011 | 01:49 PM
1) First off the AMS cam testing was 3 years ago with old crappy cams! Maybe you should do some research and see how cams have changed over the past 3 years compared to those older cams. The old S2s vs new S2s are capable of making another 20whp and that is comparing two cams almost the same size. I like how half the time you never know what you are talking about.
2) The AMS test was on a 2.0 so a cam selction is completely different than a cam for a 2.4. Also the results between the two would have been much different as VE increases at rpms increase. The 2.4 increases airflow by 20% so with a smaller cam the VE of the head is dramiticly changed in higher rpms.
3) How dare you acuse me of lying or hinding something in my "test". I hid nothing and did nothing else other than changing the cams.
The larger cams on the same spike allowed the turbo to hold more boost out the top, if you look at the boost log. That right there is enough to show you how bad the HKS cams were effecting VE in the higher rpms.
Below is the dyno overlay of the HKS cams at 30psi. It took 5psi more boost with the HKS cams to hold the same boost out the top as the GSC cams. Even with 5psi less boost the GSC cams are 58whp more than the HKS cams made.
Attachment 338713
You always seem to be the negative pos that comes in to all the threads and starts shiz. If you want to start stuff with people you can do it on a different forum.
Mikey
