Late Spool
Old Jun 9, 2011 | 06:03 AM
benderrodriguez's Avatar
Late Spool
I having an issue I can’t figure out, and I’m open to any advise. I have a 2.4 with a twin scroll GT4088 TS that is not spooling until about 6,000 rpm. It used to spool around 4,700 rpms and I can’t seem to pin down what’s changed. I recently rebuilt my clinderhead and replaced my water pump.
So far I’ve done a compression test was great 170-175 psi across the board. A boost leak test, only two real tiny small leaks (probably there the whole time). The wastegates only open at full boost and the turbo seems fine (wheel spins great, very little shaft play)
All I can think of is an exhaust leak or some other issue with the turbo. Any thoughts???
Old Jun 9, 2011 | 07:49 AM
sparky's Avatar
Originally Posted by benderrodriguez
...The wastegates only open at full boost....
What PSI are the gates cracking at?
Old Jun 9, 2011 | 12:06 PM
awdordie's Avatar
I would start by checking all the gaskets before the turbo and make sure they aren't blown and leaking exhaust and make sure the manifold to head is torqued and manifold to turbo is as well.
What boost controller, wastegates are you using that might help us. Also if u havvent already check all the vacuum lines over thoroughly.
jnut24
Northwest Region
15
Aug 26, 2012 08:01 AM
siegelracing
For Sale - Cars For Sale
48
Oct 13, 2011 08:58 AM
basm917
26
Sep 1, 2011 08:14 PM
h4ckluserr
Aug 22, 2011 11:21 AM
GregGSC
Jun 7, 2005 08:21 AM
