EVO 6 head same as EVO 9?
I was sold an intake manifold that looks like below, so it must be off an evo 6 or 7, it definitely isn't from any evo 8/9 ive seen. Are the heads (specifically intake ports) on the evo 6 and 8 the same?
A earlier JDM intake won't have EGR or a MAP sensor, but it intake ports will line up. Buschur Racing sells the JDM intake manifolds and uses one on his project car "Bad Bish" so he would be the best source for info.
But looking again at your pic that intake isn't off a VI so it probably an VIII, they didn't have map sensor either but the mount is dummied on there. Here is a VI mani painted and tapped into for SD, notice it has a much cleaner look with less mount points.
Thanks guys I just got it back from MAP, it looks like a hybrid between a usdm and jdm intake manifold. The map sensor spot has a hole drilled in it, so it definitely isnt a dummy spot.
Here is a picture of it next to my usdm evo9 intake manifold (on the right).
evo 6 and evo 9
i have both the evo 6 and evo 8 motors. the difference is the 6 hav slightly different sensors that are smaller and the evo 6-8 are non mivec. the heads on the 6 are small and the intake manifold have less wiring so if your swapping to speed density then you wont have to worry about anything..
APM Racing
43
Oct 8, 2009 04:24 PM
