Rear Diff clutch plates installed incorrectly from factory
#346
Yes I have soaked the disc's before assembling it back together. Also yes I have just recently switched my fluid to diaqueen. Got the same results but seems to be a little better. But does anyone have recommendations if I should add a friction modifier additive, or just wait a couple 100 miles? Curious
#348
My TRE 12-plate made a similar noise when first installed - filled with Diaqueen (I also have an ACD reflash which tightens things up more as well). This quickly disappeared after break-in and a fluid change.
You can still feel its action in slow parking lot turns when there is sand on the ground - it is a motorsport oriented diff after all - but there no longer is any significant noise when turning now. Works like a charm ...
#350
I just re-stacked my plates. I can't hear any new noises from the rear. I have no sound deadening, and back seats are removed, so I think I would have noticed a new noise.
The benefits are definitely noticeable. I took the car out on pavement, gravel, and snow. I just need to throw my snow tires on and really go tear it up!
#351
I had the weir 12 plate installed this summer along with the ES bushings on the diff carrier and mustache bar.
I get a little bit of whine at steady speeds around 70 mph which i think is from the bushings transmitting more noise than the factory rubber ones. Not loud but i do have full interior etc so may be louder in a stripped car.
The diff is much more locked up now. Getting on it at low speed, the rear tends to rotate very well . Does it drift way out...no....but i do have to countersteer a bit at 40 mph going around sharp bends WOT
I used Daiqueen and 2 ounces of friction modifer in the rear after the breakin as it was quite loud. clunking snapping etc. Def quietened it down without losing much of the lockup.
I found one issue that can explain the clunking etc. Prior to the install, i was checking out the rear end for a very minor little clunk. Everything was very tight on the joints etc, bushings yada
However the drivers side axle going into the diff carrier moved about 1/8 inch if you pushed on it. And it gave a slight click/clunk when doing so. Passenger side had virtually no play.
I think with the diff now locked up better, the drivers side axle moves a little more readily so the clunk is more evident. Yes i already checked to ensure the axle clipped into place correctly....
So i have questions.....Is there a plain or sleeve bushing in the diff carrier that the axle rides in ? Is it replaceable? If so does anyone have a part number ? Is the bushing the same for both sides of the diff carrier ?
bumped for answers to the questions
#352
Had this done for over a month. I also installed some Energy Suspension bushings kit for the diff. I may be one of the lucky ones that has not experienced any significant noise level increase since these mods. The car is pretty loud, but most of it is road noise and exhaust.
This has been a great mod for me, and I recommend it to anyone. I installed my snow tires a couple weeks ago and the car has been extremely fun in the snow and on gravel.
#353
Hey guys what's up.. been doing alot of research on this rearrangement on factory plates and weirs 12 plate kit..I understand that more plates equals more friction. .I have a 2006 evo 9 and was wondering since everyone has done this mod.has yheir been any issues on a dd car? My car has complete bushing kit and bars..full suspenion. Is their any more crazy noises you guys picked up from ur experience doing this mod.. how bout with the weirs kit? Thanks brandon
#355
plate work
I was told that rearrange the factory plates will work too..just won't have the bite of the 12 plate weir setup..has anyone had personal experiences with doing just that? I heard it makes it like the Japan evos?
#358
Okay so last night I rearranged the factory plates.. car is 100 percent locking in rear..I used mitsubishi lsd 90 weight oil from dealer. Car makes noises in rear when turning. Am I using the right fluid..is their something to take chattering away..
#359
That's the noise it makes. You are using the right fluid. The chattering is why mitsu rearranged the plates, to keep it quiet.
