Increasing Wastegate Spring from 1bar to 1.5bar
Old Jun 29, 2011 | 02:44 PM
david200095367's Avatar
23psi is not that much if you have the supporting mods and tuned
Old Jun 30, 2011 | 04:56 AM
boonkae's Avatar
Actually the car is running fine & the boost is very stable ...
Just wanna spool up faster ... thats all ...
Hope the increase wastegate spring will help out abit ...
Old Jun 30, 2011 | 07:54 AM
03whitegsr's Avatar
I'm not sure how the Vipec boost control works, but I would imagine there is a set point where it will start to control boost. Simply upping that set point will be very similar to the higher wastegate spring pressure at those boost levels.
You want solenoid duty cycle to be 100% until boost gets close to the desired set point, then you want the ECU to step in and start controlling things.
A higher spring pressure will help hold more boost when pushing the limit of the turbo, but higher boost doesn't always mean more power if the turbo is being overspun and efficiency has dropped like a rock.
Old Jul 17, 2011 | 04:26 AM
boonkae's Avatar
Drove my car today with the increased wastegate spring ...
The turbo definitely spool faster ... but the turbo did overboost to 2.3 bar ...
Now just have to tune it back using Vi-Pec ...
nd_danial
Jun 15, 2017 12:44 AM
danielsl1999gsx
Dec 4, 2016 11:46 PM
KingTal0n
Nov 27, 2016 05:23 PM
vr4gasmtt
Jun 14, 2015 10:12 PM
gerard
Oct 25, 2008 06:39 AM
