help something is not right........
Old Jun 30, 2011 | 10:33 AM
fabcas311's Avatar
car is fine during normal cruise and idle when the a/c is off but when i turn the a/c ON the the rpms would rise up from 1k on idle to almost 2k then back down to 1k rpms or sometimes go below 1k and the car stalls if i dont step on the gas pedal.
bad compressor?
thanks
fab
Old Jun 30, 2011 | 10:35 AM
revvin9k's Avatar
I had a similar issue using my AC which I do not use too often.
Car would stall at a stop with the AC on, called my tuner and he did his work and all has been well since. GL.
Old Jun 30, 2011 | 10:40 AM
gsrboi80's Avatar
Battery disconnected lately?
Old Jun 30, 2011 | 11:25 AM
fabcas311's Avatar
i disconnected it several times in a span of 5 months.
Old Jun 30, 2011 | 11:27 AM
fabcas311's Avatar
i hope i have the time to drive 4 hours to my tuner........
Old Jun 30, 2011 | 11:45 AM
gsrboi80's Avatar
When battery is disconnected it will need to relearn idle. Both with AC off and AC on.
This can take a couple days on my car depending on how long I drive it for. So I'd say if in some time it doesn't clear itself up your Desired Idle w/ AC On maps may need to be adjusted
Old Jun 30, 2011 | 11:49 AM
PsychDr. HN$'s Avatar
What rpm is your car idling at?
Old Jun 30, 2011 | 11:57 AM
meckert's Avatar
This is rt....will take a few days of driving to get it to settle down and adj
Old Jun 30, 2011 | 12:31 PM
fabcas311's Avatar
thanks man!
Old Jun 30, 2011 | 12:32 PM
fabcas311's Avatar
1k rpms normally when a/c off
Old Jun 30, 2011 | 12:39 PM
fabcas311's Avatar
i daily drive the car but i only use the a/c when the heat is untolerable!lol........
i was just scared out of hell yesterday when i turned the a/c on at the stop light and when i made the left turn the car stalls and the power steering turned off....S**T!......i almost hit the pavement!!
PFC McDonald
Feb 18, 2023 07:16 PM
mikebuff35
Oct 3, 2016 04:18 AM
blue4uevo8
Oct 3, 2011 11:28 AM
joedr
Aug 22, 2008 01:11 PM
DrBump471
Jun 24, 2005 07:16 PM
