OMFG Electrical Gremlins... need help
Old Jul 2, 2011 | 08:16 AM
bboypuertoroc's Avatar
Veteran: Army
Exclamation OMFG Electrical Gremlins... need help
Let me start out by saying I have no clue when it comes to electrical systems in cars.
And now, to make a very long story short... I've done two alternator swaps on my Evo. First one back in 2008 and the second a few weeks ago (second alternator a Douglas Autoworks high output). Well, today my car starts displaying the same alternator dying symptoms (first my LC-1 wideband starts resetting itself and displaying E 9 (Supply Voltage too low), then my Defi gauges turn on and off constantly until eventually just staying off, then the clock goes out, then the radio, then the rest of the dash lights, then the car just sputters until the battery has no juice to keep it on). Only weird thing I noticed was the RPMs were unusually high for the whole five minute show (holding at 2k then increasing to 3k then dropping down to barely staying on). The battery is also only several weeks old (Odyssey PC680).
Anyways, I doubt it's the alternator's fault. I believe there's something wrong with my car's electrical system but since I'm an idiot when it comes to electrical systems I have no clue what I'm talking about or where to begin. I'm sick of blowing money on alternators for it to only work a few weeks. I'm about to drive this ****ing car off a cliff.
There's a Mitsubishi dealer (apparently) in Seoul but the language barrier is gonna be an epic pain in the *** to get around. That's gonna be my last resort.
Any help is greatly appreciated.
Happy ****ing 4th of July weekend
Tony (FML)
Old Jul 2, 2011 | 08:45 AM
rgeier11's Avatar
The the volts at the battery with the car running. It should be over 12v, closer to 14.
Old Jul 2, 2011 | 09:16 AM
Veteran: Army
Say that it's not over 12v... then what?
Reason I say that is because my car is an hour away from me right now since I had to tow it to the closest military installation.
Old Jul 2, 2011 | 12:29 PM
omniprobe's Avatar
did you try replacing the battery. It could be a bad battery not holding charge. Also check terminals and straps.
Old Jul 2, 2011 | 03:05 PM
IMPdemon's Avatar
Maybe harness problems like the ones mentioned here
https://www.evolutionm.net/forums/in...s-how-fix.html
Old Jul 2, 2011 | 04:13 PM
Zeitronix's Avatar
Before you go into panic gremlin mode just grab a voltmeter and connect to + and - of the battery. It should show about 12V now start the car, the voltage should be a little higher, about 13.5V to 14V. If not your alternator is not working.
Old Jul 2, 2011 | 10:36 PM
Veteran: Army
The battery is practically brand new as I said... has only been in the car as long as the Douglas alternator (about 3-4 weeks).
Old Jul 2, 2011 | 10:40 PM
Veteran: Army
I'm trying to find out what's killing my alternator. There's no reason a new alternator should die after only 3-4 weeks. Something else is wrong.
Old Jul 2, 2011 | 10:45 PM
Veteran: Army
Yeah I read that thread last night but it looks like a different set of problems than what I'm seeing. It's still worth a look though.
Old Jul 2, 2011 | 10:59 PM
FX11's Avatar
Hey bud i ran into a similar problem where my car battery kept dying. I had the same exact symptoms.
There may be a fuse-like connector on your positive terminal. Make sure its not blown.
Old Jul 3, 2011 | 01:11 AM
Zeitronix's Avatar
There are many reasons. First you need to determine if the alternator is dead or not. So look at my previous post and test the voltage.
Old Jul 5, 2011 | 05:21 AM
Veteran: Army
Voltage is below 12... it was showing around 10.
Panda_stunter
Jul 7, 2016 08:53 AM
Dkvang920
Dec 12, 2015 09:58 AM
steve-o411
12
Jun 26, 2014 04:31 AM
Timbo42k13
Lancer Troubleshooting
May 10, 2013 06:39 AM
HN7
Sep 5, 2011 01:15 PM
