Not having good luck with tunning
Old Jul 8, 2011 | 10:48 AM
awd2gen's Avatar
Originally Posted by gkania
Your intake manifold is probably contributing to poor idle.
Your injectors are too large for 93.
You should be running hi impedence 1680cc at the most for a 6262 capable of 750hp. 2000cc high-z injectors are 1200HP fuel injectors. This is not exhaust, bigger is not better.
1680's would work better but doing that is more of a cop out and working around the issue rather than making what I know will work actually work. There are enough cars with good results from the 2000cc that I don't feel injector is the problem. I've talked to Tony at T1 and he has gotten similar setups to work with no issues.
Originally Posted by F0RSAKEN
Do a boost leak test. I'll bet you 80% of your problem is one or more severe air leaks in your system. Every problem you've described I've seen caused by leaks.
No leaks. It has all been checked.
Old Jul 8, 2011 | 10:49 AM
awd2gen's Avatar
Originally Posted by Gary@MellonRacing
Let me know if we can help =)
Might just give you a call..
Old Jul 8, 2011 | 11:03 AM
Fast_Freddie's Avatar
Veteran: Navy
It is most likely the minimum IPW patch that needs to be done with the stock ecu... I have a 2.4l AWD 272s and I idle at 1000rpm...
Old Jul 8, 2011 | 11:09 AM
awd2gen's Avatar
Who did your tuning? And what is ipw patch? I know very little about stock ecu and tuning.
Old Jul 8, 2011 | 11:10 AM
awd2gen's Avatar
Oh and Freddie are you doing that on 93 octane? Or e85?
Old Jul 8, 2011 | 11:27 AM
JohnBradley's Avatar
Lots of FIC2150 (ID2000) cars that run on stock computer, DSMlink V3, AEM, Haltech, etc. SD and 2150s definitely get a long better, the min IPW as Freddy mentioned is important to get them to idle on trims. Most big cam/intake manifold cars like 13.0 idle though anyway.
aaron
Old Jul 8, 2011 | 11:32 AM
awd2gen's Avatar
aaron
My idle afr is 12.6 and I'm still getting these bad results. If I wanted to ask the guy who tuned about ipw, what would I ask him to make sure it's where it should be?
Old Jul 8, 2011 | 11:50 AM
dastallion951's Avatar
well you want your fuel trims for STFT (short term fuel trim) and LTFT (long term fuel trim) to be + or - 3, so your tuner might have to mess with the injector scaling number or voltage to get the trims dialed in right, then you should be able to mess with the afr and timing in the idle load cells to help dial in your idle and cruising to get it better, but be forewarned he might be able to get it good, but it wont be perfect not with those injector size.
Old Jul 8, 2011 | 12:27 PM
Veteran: Navy
I do my own tuning, however learned from the best... Aaron @ English Racing... The minimum IPW patch is in the ECUflash forum, and yes my car idled perfect on 93oct and is doing great on E85 as well...
https://www.evolutionm.net/forums/ec...nimum-ipw.html
Old Jul 8, 2011 | 12:29 PM
Veteran: Navy
Incorrect, once you set up the minimum IPW patch the injectors behave great...
Old Jul 8, 2011 | 12:43 PM
awd2gen's Avatar
Thanks man I'm going to get my guy to look at that thread. I was reading it a little but it's kinda foreign to some one who doesn't know how to tune.
Old Jul 8, 2011 | 01:37 PM
Boosted Tuning's Avatar
+1
The min IPW thing is probably the issue, as Freddie has stated.
Hopefully you'll get it worked out. If you need any assistance, feel free to ask.
Old Jul 8, 2011 | 04:13 PM
red03evo's Avatar
Who else tuned your car? I thought brad brooks tuned it at first. I have been tuned by david Buschur with my aem setup and by my friend charlie(kreonic) when I was on stock ecu. Car ran great either. Your setup is similar to mine except I have a hta86.
Good luck.
Old Jul 8, 2011 | 09:50 PM
tscompusa2's Avatar
correct. great as in like this:
http://www.youtube.com/watch?v=Ajq-lwdO1XY
Old Jul 8, 2011 | 11:18 PM
interesting fast freddie, im no tuner at all but i didnt know about that patch you learn somethin new everyday, so now im curious will that patch work on the 03 rom ? im interested and not sure if my tuner has that patch setup on my car...anythin special he might have to do in the ecu modifying right in order to make the patch work?
