Whine slightly returns???
Old Jul 11, 2011 | 06:38 PM
svt_lightning01's Avatar
Okay i just suffered the death whine. Sent the case to shep trans for a stage one rebuild. I have drove the car 250 miles. I can hear a slight whine in the t case from 55-70 but otherwise it is silent. Before it was unbearably loud anywhere from 30-100 depending on the gear. Do any of you have what i would maybe assume as typical awd driveline whine like this? Or should i contact shep and ask for sure? I likely will anyways. I filled it with mitsu fluid to spec and the tranny guy is legit and followed shep instructions to spec. Like i said i may be paranoid its not very loud its just barely there from 55-70
Old Jul 11, 2011 | 06:44 PM
omar123's Avatar
some members here say it is normal for these cars to give some kind of whine is this true.
Old Jul 11, 2011 | 08:11 PM
Jonesey I7's Avatar
I have a new tcase in mine, and it doesn't whine one bit........... UNTIL 5th gear with very light throttle from 60-70ish. It isn't loud, but it is there, and it is normal. As soon as I put any type of load on 5th gear, it vanishes.... or when I get to 75-80ish it's gone completely. A little whine is ok, it's when it's constant in all gears that you should worry.
Old Jul 11, 2011 | 09:03 PM
okay man that makes me feel wonderful mine is a 6 speed and it is only in sixth under a light load about 3000 rpm or so. GREAT!
Old Jul 11, 2011 | 09:27 PM
Jonesey I7's Avatar
Yep no worries...... some guys have it in first gear too under light loads. And that is with NEW or complete rebuilds. A little whine is normal, EVEN IF it was in more than one gear theoretically, as long as it's mild and brief and NOT constant and loud.
Old Jul 11, 2011 | 09:48 PM
yeah mitsu gave me the wrong fluid for the t case and it was my first fluid change so i didn't know and they pretty much told me to shove it and wouldn't admit they were wrong. Which THEY WERE. Its a complete rebuild. All new bearings,seals, ring and pinion with some upgrades from stock! Shep does great work and 1/3 the price of dealer with better product.
Lombardi23
Mar 28, 2016 12:28 AM
jtcarstens
Apr 7, 2014 01:47 AM
blas4
25
Sep 5, 2012 07:42 PM
CaptainBoosT
Jun 13, 2010 02:37 PM
NelloMorto
11
Apr 19, 2010 07:29 PM
