ACD Pump Fitting
Old Jul 11, 2011 | 07:10 PM
Trever007's Avatar
ACD Pump Fitting
After my slight accident i was checking everything out and found that the mount for the ACD pump was bent slightly. Looked fine and the Pump was good! I took it off to straighten t out and i was gunna relocate it like i have seen done. I was cleaning it up and found that one of the steel fittings that the resivoir attaches to was bent and had fallen out. I thought i was screwed at this point. But no the casting was FINE it appears that they only glue these fittings in. The glue had cracked and it just fell out. But now the issue is i need to find another one of these fittings.
Again to explain which fitting. There is one metal line that goes to the ACD. Than there are two rubber lines that go to the resivoir that holds the fluid. These two lines are connected to the resivoir on top and to two fittings on the bottom. There is a larger hose and a smaller one. These fittings glue into the casting. I need the larger of the two. Maybe some one here can help me.
Thanks, Trever
Old Jul 12, 2011 | 01:14 AM
adam_79_2005's Avatar
I believe someone in the forsale threads is selling an acd pump and it includes all those lines/hoses are included if I remember correctly, otherwise if you just need those hoses, I'm sure you can find the sizes and probably cut to fitment
Old Jul 13, 2011 | 04:27 AM
Trever007's Avatar
Its not the hoses i need. Its the metal fittings that glue into the ACD Pump. Any one got a broken ACD pump they wanna send me for dissection?
Old Jul 15, 2011 | 04:57 AM
Trever007's Avatar
Does anyone hve a broken ACD pump they wanna sell? Only thing thats gotta be good on it is the two fittings! Thanks!
Old Jul 15, 2011 | 11:15 PM
Trever007's Avatar
No one?
joseph143
Jan 23, 2018 09:40 PM
RallyDSM
Mar 19, 2017 07:05 PM
Trever007
Mar 27, 2015 11:37 PM
Trever007
Jun 5, 2011 02:36 PM
csmith82177
Apr 8, 2011 06:07 PM
