cam angle sensor help
Old Apr 15, 2010 | 05:29 PM
timmycat's Avatar
how can i tell it the sensor it up side down? what should i look for?
Old Apr 15, 2010 | 06:50 PM
timmycat's Avatar
not sure if this is the issue, was reading around and some people say when the bat is low (which mine is) cam and crank sensor cods pop up, but not sure because the car turns over and runs for like 30 seconds then starts to misfire and it dies. how could a low bat keep the car from running?
Old Apr 15, 2010 | 09:10 PM
biggie5252's Avatar
It only bolts on one way. IXs do anyway. Are you throwing codes? If so you might need a new sensor. I had this same issue with my IX which uses a sensor on both cams. I assumed they were the same and didn't pay any attention to which one was which when it came out. It started just fine, ran just fine for about 30 secs or so, then just died. It was throwing both cam sensor and crank sensor codes. Swapped the sensors around and everything has been great since.
Old Apr 16, 2010 | 09:33 AM
timmycat's Avatar
ya both cam sensor and crank sensor codes are coming up and i just had the bat charged so i know its not that. if the sensor where messed up would it cause it to miss fire?
Old Apr 22, 2010 | 01:49 PM
20gmr's Avatar
the sensor will not go in backwards. You could have possibly swapped the trigger wheels,from intake to exhaust, or gotten the exhaust cam trigger wheel on 180 degrees off. PS both sensors are the same, the trigger wheels are different but the physical sensor is not.
Old Apr 23, 2010 | 10:44 AM
timmycat's Avatar
i have an evo 8 and there is only an exhaust cam sensor so i couldnt have mixed them up
Old Apr 24, 2010 | 08:03 AM
20gmr's Avatar
What do you have the little ground strap bolted to? Sometimes I have seen the silicone on th ebackside of the cam sensor housing cause a bad connection. Try going to a good chasis ground, there is one close to the battery in front of the shock tower
Old Jul 16, 2011 | 02:31 AM
The-Evo's Avatar
I am having this same problem right now. I will try grounding it elsewhere
raidokoiv
Aug 24, 2019 12:07 PM
Jav53_evoix
Aug 5, 2014 03:30 PM
KevinO
Dec 4, 2009 08:38 PM
maplemaf
Oct 20, 2009 12:23 PM
AbrasEvo
Jun 4, 2009 10:42 AM
