Spark plugs
Old Jul 14, 2011 | 09:09 AM
asu11's Avatar
Spark plugs
Looking to change my spark plugs on my mostly stock ix mr. WHat should I get? I saw a bunch in a thread just didnt know which one to pick.
Old Jul 14, 2011 | 09:13 AM
Montu's Avatar
I tried Denso and they kept expanding the gap some how. and misfiring
So I went to stock NGK's stock heat range and they work perfect..making 360whp on a mustang dyno.
Old Jul 14, 2011 | 09:16 AM
asu11's Avatar
Do they sell these at local auto stores?
Old Jul 14, 2011 | 09:20 AM
Kracka's Avatar
OEM NGK's
Old Jul 14, 2011 | 09:21 AM
Montu's Avatar
Not sure to be honest I just get mine from my Tuner
Old Jul 14, 2011 | 09:34 AM
asu11's Avatar
WHich exact ngks are the oem? Where would I find them?
Old Jul 14, 2011 | 09:51 AM
Drifting Away's Avatar
Ilfr7h
Old Jul 14, 2011 | 10:02 AM
asu11's Avatar
http://www.maperformance.com/ngk-las...7h-evo-ix.html
Are these correct? Do they need to be gapped?
Old Jul 14, 2011 | 10:09 AM
Yup thats them, yes unless you buy them pregapped maybe you could shoot MAP a message on here and ask if they can pregap them. Just remember when you gap these to not touch the electrode. not much to it at that point.
Old Jul 14, 2011 | 10:10 AM
mdsevo06's Avatar
According to NGK Techs, the two plugs are the same except for two minor differences.
ILFR7H - OEM GAPPED AT .024" PLATINUM TIPPED ELECTRODE
LFR7AIX - SAME DIMENSIONS, GAPPED AT .028" (WILL NEED TO BE ADJUSTED) AND ELECTRODE IS NOT PLATIMUM TIPPED.
Difference is the OEM will last longer and will not need to have the gap adjusted. For a difference of $4 a plug, you can adjust the gap and change it at 20K, instead of 30K. Sparkplugs.com has both, I went with the LFR7AIX at $7.99 and just re-gapped them.
Old Jul 14, 2011 | 10:18 AM
asu11's Avatar
So the ones I listed above are pre gapped?
Old Jul 14, 2011 | 10:24 AM
mdsevo06's Avatar
They should be gapped to .024", but should always check what you receive.
Old Jul 14, 2011 | 10:35 AM
sktng22's Avatar
only gap those iridium plugs if you know what your doing. you can easily take the iridium metal off the plug if done incorrectly
Old Jul 14, 2011 | 10:38 AM
asu11's Avatar
So just dont even bother touching them when I get them and they should be ok?
Old Jul 14, 2011 | 11:03 AM
Montu's Avatar
^ you can check the gap just to verify if you wish.
you can re adjust if needed just be careful
