oem clutch, fp green turbo?
i'm willing to go fp green/hks gt ii route, what do you guys think, will my stock clutch hold? anyone uses this setup? what about launching it?
i like the pedal feel and the engagement of stocker a lot, it's good to drive in traffic, and i'm not willing to sacrifice it unless absolutely needed. please share your opinions. thank you.
ACT XT-SD.... perfect for you. Stock feel, little stiffer. LOT stronger.
The stock clutch is only going to last for a while before it starts to go out. From the parts you listed I can only assume that you are starting to put a lot of money into your vehicle. Understand that you are now starting to invest in your Evo so dont just stop with the aftermarket turbo, invest in an aftermarket clutch also, you wont regret it.........
It will depend on a lot of things...mostly the tune. I have a green on stock clutch. My tuner set it up with lower tq (about 350) to allow for a better chance of the clutch holding. Still makes about 400 peak whp. If you are able to, I would upgrade the clutch, but it does take alot of time and money so its not always the easiest thing to have done. So the clutch will hold as long as its not high mileage, but the setup wont be optimised. One launch however and that all goes out the window
FS[South]: Fp Green Red Black etc
Wiznaz
Apr 21, 2015 07:01 PM
foxracing515151
Aug 6, 2014 12:32 PM
