How to Increase Torque?
Old Jul 18, 2011 | 06:01 PM
sparky's Avatar
jameswwt: Just out of curiosity where are you located? Where is SG?
Old Jul 19, 2011 | 02:06 AM
jameswwt's Avatar
Hi Sparky...Im from Malaysia
Old Jul 19, 2011 | 07:38 AM
RevMoto's Avatar
It's easy ditch your 30r for a stock replacement turbo like an HTA green.
Old Jul 19, 2011 | 05:54 PM
jameswwt's Avatar
Originally Posted by jameswwt
Hi guys here are my dyno chart for your kind comment...
Guys, any comment on my tuning?
Old Jul 20, 2011 | 11:04 PM
jameswwt's Avatar
Any comment???
Old Jul 21, 2011 | 06:41 AM
nightwalker's Avatar
The dyno chart doesn't tell us enough about your car's tune. If you want more torque, read the previous replies again.
Old Jul 21, 2011 | 08:19 AM
jameswwt's Avatar
Originally Posted by JohnBradley
More boost without timing will make more torque than the other way around. Where you might be at the edge with only 2-3* more timing and get 10-15 ft lbs (depending on combo) adding 2-3 lbs will make way more torque.
The best answer is the biggest motor you can afford (2.4 normally or 2.3 in a standard build). MIVEC and small cams can help do the same thing. Do you have a dyno sheet or VDR?
aaron
Hi Aaron,
say if my were tune for 1.6 bar of boost and if i slightly adjust it to 1.7 bar will it effect my tune (AFR)?
Old Jul 21, 2011 | 08:36 AM
RevMoto's Avatar
Do you have a built motor? What are your mods? Your tuner might have went conservative so you don't break anything. He is really the one you should be asking. That seems on par with most 30r's I have seen.
Old Jul 21, 2011 | 08:58 AM
jameswwt's Avatar
My current setup :
GT3076R
JE Pistons
BC I beam
Oem crank
Oem Clutch
Walbro 255
FPR
Profec B II
ACL bearings
Hi RevMoto, so you mean my power is quite average for a Gt30 and if i up boost to 1.7 bar will it effect my current tuning?
Old Jul 21, 2011 | 11:16 AM
Jonesey I7's Avatar
My current setup :
GT3076R
JE Pistons
BC I beam
Oem crank
Oem Clutch
Walbro 255
FPR
Profec B II
ACL bearings
OEM clutch@?!? Wow.... and you want it to hold MORE torque? GLWT
Old Jul 21, 2011 | 05:40 PM
jameswwt's Avatar
Is planning to replace the new oem clutch to exedy hyper single once there sign of clutch worn...
Old Jul 22, 2011 | 08:30 PM
RevMoto's Avatar
My current setup :
GT3076R
JE Pistons
BC I beam
Oem crank
Oem Clutch
Walbro 255
FPR
Profec B II
ACL bearings
Yeah, unless pushed to its limits I have never seen a 30r do too well on a 2 liter and low boost. Upping boost will have an affect on AFR sure but how much I can't tell you. JohnBradley is a pretty smart guy so I would listen to what he has to say. Also that is nuts how you are on a stock clutch.I could only imagine how much longer that is going to last. People with a built motor do tend to run higher boost than what you are running.
Old Jul 22, 2011 | 08:41 PM
evo8426's Avatar
45kg m translates to only 325tq so he is definitely not even close to the clutch slipping on normal driving such as not launching the car.
jameswwt, I think you should have your tuner turn up the boost to more than 1.6-1.7bar (23-24psi) and adjust the tune. I believe thats where all your torque is hiding
Old Jul 22, 2011 | 10:20 PM
jameswwt's Avatar
Thanks Guys really appreciate it...
Old Jul 23, 2011 | 05:04 AM
boonkae's Avatar
Actually from what i see on your chart ...
You are already running on 1.68 bar ... So 1.7 won't help much ...
Just like everybody is saying ... Try increasing to 1.9 or 2 bar ....
