Help Identifying Parts from the Head!!!
Old Jul 21, 2011 | 08:08 PM
Babs's Avatar
Alright so I THOUGHT I stripped my head bare when I sent it to get cleaned and resurfaced at the machine shop but they pulled out these three parts that I need help identifying with what they are, where they go, and in what order (if any).
I know the camshaft looking piece is the oil feeder control valve. It says in the manual that an o-ring goes on the end of it so I guess I'll need a new one of those. But what are the spring and the strainer and what do they go to? It just kinda makes sense that the spring goes under the the stick since it is a valve but it doesn't show any kind of spring in the manual. And I'm clueless as to what the strainer is...
Thanks guys!
Old Jul 21, 2011 | 08:39 PM
n2oiroc's Avatar
looks like something for the mivec, but i cant stop looking at that carpet! its mesmerizing!
Old Jul 21, 2011 | 10:40 PM
uvambo's Avatar
dude that rug ties the whole room together....
Old Jul 22, 2011 | 05:30 AM
Babs's Avatar
Awesome...can I get an on-topic answer so I can put my head back together?
Thanks
Old Jul 22, 2011 | 08:35 AM
EAVWIDL's Avatar
does the carpet match the curtains
Old Jul 22, 2011 | 12:37 PM
RSMike's Avatar
mivec feed filter
mivec plunger (that controls the mivec oil pressure) without the orings
spring? for mivec
Old Jul 22, 2011 | 02:25 PM
Babs's Avatar
Originally Posted by RSMike
mivec feed filter
spring? for mivec
Awesome thanks man...do you know in which order these go in the head? And where does the feed filter go?
Thanks again.
Old Jul 23, 2011 | 01:39 AM
RSMike's Avatar
you're missing a lot of parts.
do you have everything else?
Old Jul 23, 2011 | 07:02 AM
Babs's Avatar
What are you talking about like the sensor that goes over it, all the valvetrain and whatnot? Then yes...
What other parts were you talking about?
Old Jul 23, 2011 | 07:26 AM
Babs's Avatar
OK I found out where the feed filter goes and how it goes in...it was in the "Supplement" section of the manual.
Now I just have a question about the spring. There's supposed to be an o-ring that goes into the head before the pressure valve so does the o-ring go first, then the spring, then the valve, and then the sensor? Or is the order different?
Thanks again!
Old Jul 24, 2011 | 01:03 AM
evo8jedi's Avatar
Carpet bump!
Old Jul 25, 2011 | 09:15 AM
Babs's Avatar
Up...does anybody know the order of the spring/o-ring/pressure valve?
Old Jul 25, 2011 | 09:21 AM
gkania's Avatar
Looks like you snapped off the MIVEC oil control valve. That metal plunger is not supposed to come out of the control valve. Looks like you need a new one now since it looks broken off.
Old Jul 25, 2011 | 09:42 AM
Babs's Avatar
It's definitely not snapped off. Both sides of the valve are still very smoothly machined.
By the way, you live in Deltona? What color is your car?
