evo 8 & 9 transmission question
Old Jul 25, 2011 | 12:26 PM
jshad315's Avatar
I have an 05 EVO mr and wasnt sure if a 06 EVO Mr trans would bolt right in
Old Jul 25, 2011 | 02:05 PM
ElectricBlueIX's Avatar
Should be the same.
Old Jul 25, 2011 | 02:23 PM
Teal2nnr's Avatar
It will
Old Jul 25, 2011 | 08:11 PM
jshad315's Avatar
Thanks good to know since I will be installing it this weekend ... First EVO trans
Old Jul 25, 2011 | 11:02 PM
Graphic's Avatar
Make sure you have a slide hammer. The TOB can suck but you'll get it. Jam the screw driver in twist and pull clutch lever to pop off input shaft. Enjoy Other than that it's pretty simple if you've done a transmission before.
Old Jul 25, 2011 | 11:04 PM
02-Lancer-Es's Avatar
Originally Posted by graphic
make sure you have a slide hammer. The tob can suck but you'll get it. Jam the screw driver in twist and pull clutch lever to pop off input shaft. Enjoy other than that it's pretty simple if you've done a transmission before.
+1
Old Jul 26, 2011 | 03:40 AM
jshad315's Avatar
Thanks for the insiders cause I don't have a slide hammer
OneCrzyEvo21
May 24, 2016 10:57 PM
sunrichmond
MitsubishiParts.net - WA
Jun 9, 2014 10:21 PM
Fairclough
Jul 23, 2010 06:48 AM
Evo Ed
30
Nov 16, 2004 06:16 PM
