Foggy headlights? This is a great way to fix em.
Old Jul 26, 2011 | 07:09 PM
VRSF Tiago's Avatar
Tried this on a few cars and it's worked beautifully! You can get the stuff at most local parts stores (Autozone/Napa/Advanced)
http://www.youtube.com/watch?v=_t1RBw0IGXA
Old Jul 26, 2011 | 07:30 PM
n2oiroc's Avatar
i use 1,500 or 2,000 grit wet sandpaper and a buffer.
Old Jul 26, 2011 | 08:16 PM
VRSF Tiago's Avatar
That works as well, the 3m kit is a bit easier to use for the guys looking for a package deal rather than having to source stuff individually.
Old Jul 27, 2011 | 10:20 AM
awdordie's Avatar
No chemical/buffing compound I have ever used has lasted a decent amount of time. Oxidation still reoccurs over time. The ONLY thing I have found to eliminate this problem completely and to never reoccur is to use 2000g sandpaper wetsand the lens and then clear coat them with a clear with uv protectant. The oxidation has never came back on any headlight I have done this way including an eclipse I did 6 years ago.
On top of that, this way is easier and safer since you sand by hand, and then just clear. When you use a buffer or drill like shown in the video you run the risk of burning the plastic lens and ruining it. Once it has the yellow/brown burn mark it is done and looks like s**t. I've done plenty by removing the headlight assembly and professionally clearing them, and have had good success just masking a few vehicles headlights off and and clearing them. Either way I haven't seen a product made for this that lasts, and let's face it who wants to do something over and over and over.
Old Jul 27, 2011 | 10:21 AM
VRSF Tiago's Avatar
The 3m process utilizes actual sandpaper
Old Jul 27, 2011 | 12:54 PM
EVO8emUp's Avatar
Exactly! They must be cleared with a UV protection. Mine are original and still look new. I've only used Plexus to clean them.
http://www.plexusplasticcleaner.com/frames.html
Old Jul 27, 2011 | 01:14 PM
FX11's Avatar
yes, from personal experience, the 3M kit works amazing. I've used it all my old cars. It comes with everything. Also its easy and simple.
Old Jul 27, 2011 | 09:34 PM
VRSF Tiago's Avatar
I've had success for over a couple years with this product on my older DSM until I sold it. Only had to do this once
