EGR blockoff plate stuck from RTV
Old Jul 31, 2011 | 10:25 AM
nytalonTSi's Avatar
I'm looking to reinstall the egr valve in my car, when I blocked off the egr only using a gasket it wouldn't create a good seal. The only way I was able to stop the leak was to use a gasket along with some red high temp RTV.
Trying to take off the block off now isn't working out, I hammered it with a mallet but no dice.
What can I get that will soften the rtv between the intake mani and the blockoff plate?
Thank you.
Old Jul 31, 2011 | 12:40 PM
BluEVOIX's Avatar
Well at least you know it didnt leak.
Try to use a razor blad and see if you can slide it between the plate and manfold to break or cut the seal. Then maybe use a thin flat head screw driver in a prying manner to get it off. But be careful not to mess up the flat surface.
Old Jul 31, 2011 | 12:45 PM
CurseDSM's Avatar
after you get it off make sure you take that razorblade and clean the surface clean then reinstall the egr.
Old Jul 31, 2011 | 03:35 PM
nytalonTSi's Avatar
Haha, your right about that, the SOB sealed lol.
Thanks guys.
fostytou
359
Oct 23, 2025 09:54 AM
kaonashi
Jul 29, 2012 06:55 AM
B.J.@ToxicFab
Feb 29, 2012 04:07 PM
4g94T
Lancer Aftermarket Forced Induction Tech
Jul 12, 2011 02:57 PM
fostytou
Oct 18, 2009 08:53 PM
