Torque Solutions EGR plate
Old Jul 27, 2012 | 02:25 PM
kaonashi's Avatar
Was this suppose to come with a gasket? I saw that STM has a gasket with their block off plate. I think its causing my car to run rich letting air out... There was no OEM gasket on when i removed the stock EGR system. Can someone chime in? I put black RTV on it to seal it but, its not sealing.
Old Jul 27, 2012 | 02:28 PM
ezzey's Avatar
i have the stm one and am NOT using a gasket, but i AM using Permatex Ultra Grey RTV Sealer.
I applied it on the block off plate nice even thin layer, reinstalled, let dry over night, and leak free at 30psi under leak test.
Blue91lx's Avatar
Yeah. There should be a metal gasket. (It doesn't come with it, but you should use one).
Old Jul 27, 2012 | 03:23 PM
wazzelby's Avatar
If you're really in a pinch, pull off the plate and trace it out on a tin soda can. Cut that out with tin snips and you have a quicky gasket that will seal up your EGR.
GHETTO-FABULOUS!!
Old Jul 27, 2012 | 04:32 PM
kaonashi's Avatar
GHETTO-FABULOUS!!
Nah its no biggy i ordered a oem gasket, some of my wot pulls end up dropping to low 10s, when its normally 11.5-7s, & some time's my idle goes Lean 16.7s
Old Jul 28, 2012 | 05:14 AM
AWD Motorsports's Avatar
It does not come with a gasket. We use permatex rtv silicone and they seal perfectly.
Old Jul 28, 2012 | 09:28 AM
kaonashi's Avatar
I guess the RTV I used wasn't strong enough, So permatex grey works good ? is there a better kind recommended?
I used this :
http://www.permatex.com/products/aut...sket_maker.htm
Maybe I didn't let it cure long enough.
Old Jul 28, 2012 | 11:27 AM
Blue91lx's Avatar
You should use the Ultra Grey.
Old Jul 28, 2012 | 11:45 AM
kaonashi's Avatar
Ok I'll clean it off & get some ultra grey, I have to buy a new T35 bit mine came up missing so I'll pic some up today. Does this sound like it might be the cause of my rich idle & WOT pulls?
Old Jul 28, 2012 | 01:23 PM
grim~'s Avatar
i noticed you have self tuned in your sig. You might wanna post up some logs and your rom in the ecuflash section to make sure your tune is ok. Or have Tscompusa look at it,he made my car run 100% better than i had it,
Old Jul 29, 2012 | 06:55 AM
kaonashi's Avatar
Yeah, I can get some, my HDD in the laptop burnt up some im waiting on my new one. I didn't have to adjust anything until after i removed the EGR. everything was pretty much dead on afr.
I put the ultra grey on last night, letting it cure for the 24hrs it calls for, Also found a minor leak from my mbc the valve nut wasn't seated 100% tight. I'll find out if anything changes from those 2 things around 5pm
fostytou
359
Oct 23, 2025 09:54 AM
LakerRaider
May 17, 2017 04:20 PM
slowsrt4:(
Apr 19, 2014 03:46 PM
davezorz
AEM EMS
Feb 27, 2013 08:23 PM
4g94T
Lancer Aftermarket Forced Induction Tech
Jul 12, 2011 02:57 PM
