Arashi Turbochargers
No high mileage update yet. I am still only at 900 miles. My island is small so I might do 700-800 miles in a month.
It is still going strong though. I plan on increasing the boost from the 11psi it is at now to 20psi as soon as my new to me boost controller arrives.
Any results? According to their website they are Japan made. I imagine they would perform just like any 20g upgrade. I just happened to notice them on Ebay so was curious if anyone used them.
Arashi Performance located in Saitama-ken(埼玉県), Japan, is a professional enterprise in designing and manufacturing high performance turbochargers since the early 2000.
In addition to high performance turbochargers, wastegates, and fuel injectors, we also provide many other performance products such as fuel system components and engine management systems
Arashi Performance is committed to offering full technical support on each and every product sold.
Just call or email us today for a quick and courteous response. You will be very glad you did.
I'm thinking about buying this turbo, but at their site written what "For application on EVO 4-8, EVO9 compressor outlet pipe is required."
So there is a question. Which difference between Evo 4 and Evo 9 outlet pipe? It's so necessary to have Evo 9 outlet pipe for it?
After ~1100km max boost is only 0.7 Bar, and it's bad
And if actuator was 1.2 Bar, then why after installation it was only 0.9 Bar max?
Problem with wastegate flap?
If I remove hose from actuator, it's boost over 1 Bar.
Its cause the metals they use are akin to particle board but in steel form....the flapper is not sealing good and the actuator probably is made of paper or something chessy. Not trying to slam just being real. Get a stock actuator and test it...or if you wanna get deep..take turbo off an look at the flapper sealing surface....youll see what im talking about.
BoostINurI, so, how I can fix it?
I'm checked actuator with hand pump and manometer for response on pressure - it really fully opens gate at 1.2 Bar.
todd6027, yep. It was good enought, and after increasing (1-2mm) preload, boost now is only 0.7 Bar. Before change was 0.6 Bar.
Yesterday was kinda funny. Boost was gone. Fully. Driven as 1.5L engine car or something like it.
After 1 hour in garage (don't touched engine) boost was returned O.o
I'm think, my bypass valve just freezed at -38°C and was always opened xD
But maybe actuator is working wrong too.
And lately, increased actuator preload. Forgot to connect hose to actuator. Boost was 1.5 Bar
Connected hose - under 0.9 Bar ^_^
