Arashi Turbochargers
I'm probably going to get one of these very soon.
We'll see how it goes.
To be honest, at the price they're selling at (about 560 USD In China), I'd consider it a win if:
a) They actually fit the evo 9.
b) if they were made in Taiwan and not China. I don't have much faith in them being "manufactured in japan".
Give me a few months, I'll let you guys know how it goes.
Today, over 3000km of using this TC - flight normal =)
tianma_evo, seller on eBay said it manufactured in Japan, but warehouse is located in Taiwan. I'm not believe it too much, but it seems quality of this TC is good.
RE-MAGAZINE MECHANICS- who do not know shiznet.
Its cause the metals they use are akin to particle board but in steel form....the flapper is not sealing good and the actuator probably is made of paper or something chessy. Not trying to slam just being real. Get a stock actuator and test it...or if you wanna get deep..take turbo off an look at the flapper sealing surface....youll see what im talking about.
:sho cked:
-RE- MAGAZINE MECHANICS AND THEIR BS KNOWLEDGE, OR LACK THERE-OF...-
YOU, SIR- ARE TALKING OUT YOUR STINKY BACK-SIDE. You obviously have no REAL Knowledge of the materials and processes that go into these High-Quality Turbos.MAIN WEBSITE / COMPANY LINK: http://www.kamakdynamics.com/
Here are pics and specs of some really nice turbos: FACEBOOK PAGE-
https://www.facebook.com/kamakturbo/app_251458316228
I have the 22+ Years Of Hands On ASE MASTER CERTIFIED auto repair and service.. Plus, and I am a A&P Aviation Technician (FAA Licensed in July of 1991)-HONORS graduate, letter of recommendation, perfect attendance, 96% average of all 12 blocks/classes.JUST SO YOU KNOW: If you send: For example a GREDDY- Model Type: 05H-18G from a Honda CRX/Si (1988-1991 B16A-B18A V-Tech, etc)to get rebuilt. Most repair facilities use cheaper bearing material than your so-called "paper/particle board" quality bearings and thrust plates that Arashi and Kando/Kinugawa use.
Arashi and Kando also use a 360* thrust bearing w/ 2 oil supply holes. I would not question MY KNOWLEDGE: It is based on "Hands-On" experience and I have BACKED UP MY KNOWLEDGE / CLAIMS with actual Vehicle Installed Turbos.
My 2005 Subaru has a TD05H-20G turbo ran @ only 20psi -93 oct. (379whp/357wtq) and I just Ordered The Arashi 3" inlet : TDO6H- w/ a 60-1 series compressor - capable of 500 + WHP. A 3" inlet , 1200cc dw'S, dw 340lph f-pump. Adjustable atmospheric BOV. CAI - 3".
Application - EJ20 EJ25 SUBARU IMPREZA GC8 / GDA / GDB Single Scroll Turbo.
- EJ20 & EJ25 engine.
- Stock Position Replacement.
Bearing Type Journal Bearing / Performance Thrust Bearing Kit with larger thrust ring and flinger.
Cooling System Water cooled
Compressor Wheel 60 mm / 76 mm (Inducer / Exducer)-
Turbine Wheel 67 mm/ 58.8 mm (Inducer / Exducer)
Actuator Pressure 1 Bar / 14.7 PSI
Turbo Boost Limit 41.16 PSI (can safely run 32-35 psi on E85 all-day/year long+then some !!!!!) 2.8 Bar (Based on Performance bearing kit with larger thrust bearing )
A GREDDY TDO6H-25G is only 60.5mm / 78mm link:
http://forums.nicoclub.com/td06h-25g...y-t348740.htmlCondition
Warranty Brand New
The compressor diameter is only .2mm smaller than a ATP GT3076R !!! And, My GOD, The Turbine Specs are the killers: THE
-Wheel: 60mm w/ 84 trim
-Maps
Compressor
-Wheel: 76.2mm w/ 56 trim
-Maps
OTHER MITSUBISHI TURBINE SPECS:
TD06h:
Inducer - 67.2mm
Exducer - 58.8mm
TD06SL2:
Inducer - 61mm
Exducer - 54mm
TD05h:
Inducer - 56mm
Exducer - 49.2mm
THE MONSTER TDO6H-25G - Another option for my turbos:
Chra TD06H-25G
Wheel spec. Compressor wheel: 60.5 / 78 mm (25G)
Turbine wheel: 58.8 / 67.2 mm (TD06H / 11 Blades Inconel Wheel)
http://www.modifiedcartrader.com/for...ru-Impreza-STi
I never installed it on my car.
It turned out that the product actually being sold was an Arashi Compressor wheel for the mitsubishi turbo, and not an entire turbo.
I can't find these things in China, and, haven't really been looking anymore.
25g kinugawa over 5k miles not sure how many didnt really count
Making 450 to the wheels, amazing turbo, fp performance conpares this turbo to thier FP red, and will make about 500hp on e85
But if you want to get more power go with an FP black overall
Goal for me was 500 but 450 was close enough due to kinugawas wastegate not holding. So buy the turbo and get an fp wastegate
kinugawa 25g
ive have the 25g installed on my evo 8 for a year and 21k miles know with no issues,updated wastegate spring(1.5 bar) car runs 18lbs on spring made 305hp and 287tq on stock injectors 91oct, my 92 eclipsehas the same turbo with t3 housing 110 race fuel at 29lbs made 505hp 389tq was at its limit power curve was good even through and automatic trans hade this turbo for 4 years variuos types of fuels(e85,av gas,pump,blends) so im very comfortable with them.
Where can you get the t3 housing for the 25g?
Would like to keep the same turbo possibly and go forward face setup thos turbo is a beast.
Anyone know the max output of the 25g
:sho cked:
Warranty Brand New
-Maps
Compressor
-Maps
TD06h:
Inducer - 67.2mm
Exducer - 58.8mm
TD06SL2:
Inducer - 61mm
Exducer - 54mm
TD05h:
Inducer - 56mm
Exducer - 49.2mm
Chra TD06H-25G
TO answer the question since it doesn't look like any one knows, here is the true update:
Arashi TD06SL2R-20G-10.5 (http://arashidynamics.com/products_detail.php?id=54)
And
Tomei Arms m7960 (https://www.tomeiusa.com/_2003web-ca...s_m7960-e.html)
ARE THE SAME TURBO.
Just branded different.
It does look like in the last year, the m7960 has seen an update.
But as of 2015 when I bought my Arashi, and then my FP RED, the Arashi Build Sheet and the Tomei Arms sheet were identical.
I heard through a friend who lives in Japan, that they were both manufactured on the same property.
And
ARE THE SAME TURBO.
FS[West]: BBK Full Turbocharger Evo 8-9
20valves20lbs
11
Feb 13, 2017 02:30 PM
