-8 an fitting on a fuel rail?
Old Aug 6, 2011 | 11:25 AM
NOMIEZVR4's Avatar
Hey guys, I bought a full blown fuel pump with -8 an lines. The fuel pump part of the system is set to go, the only issue I am having is setting up the fuel rail.
The -8 an line runs from the fuel pump up to the fuel rail and here is the problem, I have a stock fuel rail and would like to keep it.
Can I take my stock fuel rail to a machine shop and have them machine a -8 an fitting onto the fuel rail?
If not how can I make this setup work? I just need one side of the rail to have the an fitting and the side with the stock fuel pressure regulator to stay the same.
Old Aug 6, 2011 | 11:38 AM
psphinx81's Avatar
http://www.streettunedmotorsports.co...el_fitting.htm
problem solved
Old Aug 6, 2011 | 11:49 AM
NOMIEZVR4's Avatar
Thanks alot!!!
Man that saved me alot of time !!!
Old Oct 17, 2022 | 04:15 AM
harryowen's Avatar
I used the Radium Venturi Jet Pump at an super stable @ 50psi with the vacuum line off and plugged, and about 43psi when hooked up and idling. no more jerky throttle cause of high FP.
amsevokid
Mar 3, 2014 08:30 PM
DvlInDskyz
Aug 18, 2010 03:39 AM
JeffGST
Oct 19, 2007 11:45 AM
sekula
Oct 2, 2007 07:15 PM
socalmr
15
Feb 6, 2007 12:54 PM
